Old 10-17-2016, 02:58 PM   #1
Eman
Liked 133 Times in 76 Posts
Default front tire rollout measurement 25"&26"
Looking for actual front tire measurements of 25"&26" tires. My Phoenix 26" are 84" measured with a tape arond the center of the tire. I'm looking to drop down for better RT's.
Old 10-17-2016, 04:56 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: front tire rollout measurement 25"&26"
Stick or automatic? If your lights are late, I would work on myself or the car. Those are shorter than mine. 26.75" diameter is 84" around with a tape measure. Mine are 28" tall. (88" circumference) Personally, I would not shorten my tires to make my lights look better. There are much smarter people here than me, that may tell you different.
Ed Wright 4156 SS/JA
Old 10-17-2016, 08:04 PM   #3
7423
Ed is right, no pun intended............................one inch in diameter is worth .01 in RT, hardly worth the trouble. Work on your car or get sharper on the tree or both.
7423 is offline   Reply With Quote
Old 10-17-2016, 11:09 PM   #4
Eman
I work on the car and myself regularly. Frt. tires are worn out so I need new ones anyway.
If anyone could put a tape on their tires i'd appreciate it.
Old 10-18-2016, 08:40 AM   #5
Liked 10,852 Times in 2,254 Posts
To get a rough idea C= 3.1416 X Dia.
Old 10-18-2016, 09:27 AM   #6
j gardiner
Liked 55 Times in 29 Posts
Running a smaller front tire is an example of working on the car. There is no magic dust that will instantly give you better results, but every bit helps. You won't know till you try.
j gardiner is offline   Reply With Quote
Old 10-18-2016, 09:53 AM   #7
Jeff Blanchard
My 26" Hoosiers measure 81-1/2", inflated to 34 psi on a 3-1/2" wheel. I looked at your measurement again before posting this and saw the big difference, so I measured again, 81-1/2".
Jeff Blanchard
353C / Stock
Jeff Blanchard is offline   Reply With Quote
Old 10-18-2016, 02:53 PM   #8
Ed Wright
Ed Wright's Avatar
If you need small front tires to get a good reaction time, your doing something wrong, or have a very slow car.
Old 10-18-2016, 06:14 PM   #9
MR DERBY CITY
Liked 8,131 Times in 1,535 Posts
OR....MAYBE our personal reaction times aren't as good as you.....EDDDDD......
Old 10-18-2016, 09:33 PM   #10
ghost
Liked 16 Times in 11 Posts
On my time slip, i prefer get three right LETTERS (win) VS to 3 right NUMBRERS (best time)
ghost is offline   Reply With Quote
