Old 10-28-2016, 02:42 PM   #11
Jeremy K
Default Re: Tech Updates/Revisions--Alum heads in SS/CS?
SECTION 11D: MODIFIED STOCK, ENGINE:1, CYLINDER HEADS (Page 16) (10/25/16)
V-8 splayed valve permitted in AS, canted or inline in BS, inline only in CS, and any valve configuration in DS. All heads must be NHRA-accepted, two valves per cylinder, except in classes DS, ES, FS, and GS, four valves per cylinder permitted. Aftermarket aluminum cylinder heads permitted except in CS. Angle milling and/or rolling permitted. Aftermarket iron heads permitted in CS. Porting, polishing permitted; header plates permitted. Exhaust port plates that protrude into port prohibited. Any valve size permitted, valves may be tilted and/or canted. Combustion-chamber modifications permitted. The valve cover rail may be modified. Heads may be cut for larger pushrods and valve springs. External modifications permitted in port area except for
SS/CS. Spark plug holes must be in NHRA-approved location.
I didn't put the important parts in bold in my last post.
Jeremy K is offline   Reply With Quote
Old 10-28-2016, 03:29 PM   #12
SSDiv6
The new proposed rule is clear as mud.
It appears that any non-OEM aftermarket aluminum head is allowed.
Also, for SS/CS, my interpretation is that any non-OEM aftermarket iron head is allowed.
They also crossed out the language that prohibits the use of billet heads.
I hope the final rules are more specific because this will open a can of worms!
