Old 10-23-2016, 06:17 PM   #1
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Default LT1 tuning help
I took delivery of Peter Oliviera's 94 Camaro stocker yesterday in Las Vegas. I will be racing it in the nationals this week. I need some tuning help with it. I know nothing about tuning a fuel injection system yet. I will learn it. It is the Holley Commander 950 system. It has a severe drivability problem between idle and 3000 rpm. I'm open to suggestions. Thanks for any help.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 10-23-2016, 07:11 PM   #2
J.R. Haddad
Liked 1,471 Times in 308 Posts
Default Re: LT1 tuning help
Darrel, you sound just like me when I bought my F.I. Stocker. I kept opening the hood looking for the q.j. carb. I still don't know much, but I assume when Peter last had the car it was fine. That would have been at Seattle which right now-6:00 CST at my house, is at 823 FT. Vegas right now is 3881. Just like when you go to Denver, it's too rich. It is still too rich above 3000 RPM, it just clears up to make it more drivable at higher rpm. Phone Peter, tell him you want to lean it 3 numbers or 5% from 4000 down to idle. If it still feels funny, go down 1 number at a time until it runs the way it should. Just think of 1 number on the Laptop (up or down) as 1 jet size in your carb. Let me know if I can help, or find you help. J.R. Haddad.
J.R. Haddad is offline   Reply With Quote
Old 10-23-2016, 07:47 PM   #3
Darrel Goheen
Thanks JR. Peter said he's never tuned the car and has never changed it and he doesn't know how. As I type this I'm setting in the car in the trailer and trying to get laptop to read the box. No luck yet.
Old 10-23-2016, 08:57 PM   #4
Angelo DiTocco
Angelo DiTocco's Avatar
Liked 189 Times in 48 Posts
Try changing the map sensor and coolant temp sensor. There are ways to check them but if you are unfamiliar with the software it might be faster to change them at least just to rule them out as the problem.
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Angelo DiTocco is offline   Reply With Quote
Old 10-23-2016, 11:02 PM   #5
Darrel Goheen
Got it to run thanks to Derek Hake! He found a tune to load. I loaded it and it runs great! Thanks Derek. I'm pretty excited about this fuel injection thing now but have a BUNCH to learn. Thanks everyone else for the suggestions.
Old 10-24-2016, 08:22 AM   #6
Jon Sarrett
Jon Sarrett's Avatar
Liked 140 Times in 46 Posts
The 950 is a pretty easy system to play with. I started with it and eventually moved into a FAST 2.0 this summer. Pay attention to your logs and what they are telling you.
I fought an idle to 3kish misfire all summer. Turned out to be my opti. I put one of the MSD billet jobs in there and no more issues. Something to keep in the back of your mind. I have found these are fun cars to drive and there are some really fast ones out there. Have fun with it and if you need help, let me know.
Jon Sarrett
Stock 3779
Jon Sarrett is offline   Reply With Quote
Old 10-25-2016, 03:07 PM   #7
Darrel Goheen
Thanks Jon, I just discovered what I think will make a huge difference. One of the 3/8'' vacuum lines was off of one of the PCV valves. It has a newer MSD Opti Sparks on it. I got a spare too. Optispark doesn't seem to be one of GM's better ideas.
Old 10-28-2016, 01:33 PM   #8
cmracing
Liked 62 Times in 29 Posts
I think an ex-FORD engineer designed the Optijunk system!
And for what it's worth, toss the Holley 950 and put a Holley HP setup in there.
cmracing is offline   Reply With Quote
Old 10-28-2016, 04:08 PM   #9
Darrel Goheen
I'd love to do that but that'll be a long time before I can do that probably. $1600 upgrade Holley said.
Old 10-28-2016, 06:06 PM   #10
bob shirley
get in touch with ed wright .he is on here. that's his business
bob shirley is offline   Reply With Quote
