Old 11-27-2016, 10:09 PM   #1
wrenchnone
Default BBC Mondello Cylinder heads ready to go
I'm not sure where to market these. Looking for someone who needs to run cast iron heads for their class. I've got a great set of heads for sale. Can someone point me in the right direction to sell? Thanks John
wrenchnone is offline   Reply With Quote
Old 11-28-2016, 10:41 AM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 310 Times in 104 Posts
Default Re: BBC Mondello Cylinder heads ready to go
What casting number?
What size valves?
How are they modified,normal port and polish or stock appearing?
With a little info maybe we can get you pointed in the right direction.
Mike Taylor 3601
Old 11-28-2016, 08:52 PM   #3
wrenchnone
Thank you Mike, the GM number is 3994028 (or 26) date code 1-9-71 and 1-2 -71 The Mondello serial # is 19572. They are 117 cc Open Chamber, Ported and Polished by Joe Mondello, Valves are Manly stainless steel 2 1/4" intake, 1 7/8 exhaust, with spring pockets cut for 1.625" springs (can use std GM springs with cups). Has ARP rocker studs with push rod guides.
Titanium retainers. K Motion springs with 40 runs. Complete valve job / guide service within 40 runs. Leak checked and ready to run. Pictures on request. Probably something I'm forgetting but this should give you the idea of what I've got. Thanks for the help, John
Old 11-29-2016, 10:39 AM   #4
Mike Taylor 3601
Not anything that can be used on stock or super stock car,they are plenty of bracket, .90 or street that should be able to use them,only problem is with work you have, that is done you probably have quite a bit of money tied up in them and if you ask too much most will buy a new aluminum head.
Might be desirable heads if someone is looking for those casting number/date code,usually mods doesn't matter to them,they just want the numbers to match.
Mike Taylor 3601
Old 11-29-2016, 08:19 PM   #5
wrenchnone
Thank you. I'll post on racing junk. Just wanted to check here first. any idea of a reasonable price to ask?
Old 11-30-2016, 01:34 AM   #6
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Wrench…That cylinder head casting number should be 3994026 they will be a Rectangle Port head and would have been from a 1971 LS6 offered in a Chevelle or Corvette. You might want try and sell them as such. Hope this helps. MB.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 12-02-2016, 07:00 AM   #7
wrenchnone
Thanks Maurice, I'm familiar with chevelle.net. Perhaps someone over there would be interested. I appreciate your help. John
Search this Thread:
Advanced Search
