Old 12-05-2016, 10:12 AM   #1
PozQB14
Liked 42 Times in 17 Posts
Default Steering question
What are the stipulations on steering dampers, specifically on a 3rd gen Camaro? Stock and/or super stock. Getting some nasty tire shimmy on the landing.
PozQB14 is offline   Reply With Quote
Old 12-05-2016, 11:39 AM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Default Re: Steering question
Ed Quay has a nice kit for that car. Typically if you have shimmy something is loose. I had the same issue on my gen 1 Camaro. Turned out the top bolts on the steering box were loose. Check to make sure everything in the steering system is tight and no slop
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 12-05-2016, 12:05 PM   #3
PozQB14
Thanks Mike, I saw that damper but is it legal in stock/super stock? I'm pretty vigilant on checking the car over between runs, keeps my mind busy.
Old 12-05-2016, 01:13 PM   #4
MR DERBY CITY
Liked 8,045 Times in 1,527 Posts
Almost all 3rd gen camaros run that ed quay piece, actually an early VW absorber...its legal and very important if you don't want to shake the fillings out of your teeth....
Old 12-05-2016, 01:45 PM   #5
PozQB14
Thats the million dollar answer I was looking for, thanks!!
Old 12-07-2016, 09:38 AM   #6
Eman
Liked 133 Times in 76 Posts
Just about every S or SS 3rd gen has one, the others will have one if they wheelstand. As stated there is a problem on those cars cracking the frame behind the steering box and the frame rails flexing. There is actually a factory piece and it's sold aftermarket also that ties the L and R rails with a bar between the sway bar mounts to stop flex.
Old 12-07-2016, 09:45 AM   #7
Ed Wright
Ed Wright's Avatar
Wonder what makes the 3rd gen cars shimmy at landing without one? My 4th gen never has. This is the first I've heard of this. Interesting.
Ed Wright 4156 SS/JA
Old 12-07-2016, 10:14 AM   #8
PozQB14
Up until this past weekend I never really made enough power to even bring the front wheels off the ground. So it definitely surprised me when the steering wheel went nuts for a quick second. Probably going to go with the Quay damper and see how that works. I think it has to be welded on.
Old 12-07-2016, 10:40 AM   #9
MR DERBY CITY
2 small brackets need to be welded......
Old 12-07-2016, 11:31 AM   #10
Signman
Liked 269 Times in 99 Posts
Check your steering completely!
Had violent steering wheel shake out of the blue one weekend at Atco a few years ago.
After it left and picked the wheels up steering wheel started shaking and got worse until I stopped the car on the track. Went back to the pits checked what I could tried again same thing.
Tie rod ends and steering box were tight did the standard check on the ball joints for vertical movement but on further inspection there was ball joint movement front to rear.
Replaced the ball joints and added the damper from Pete Z for safety in the future. Pete mentioned tightening the large nut on the bottom of the idler arm if OEM will act like a damper.
