Old 12-11-2016, 12:29 PM   #1
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Chrysler Solid Roller Lifter Question
Is there any companies making tie bar style solid roller lifters for a Hemi or Big Block Chrysler engine ? Looking to avoid hurting pushrods when using high load valve springs .
Old 12-11-2016, 02:33 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Chrysler Solid Roller Lifter Question
I would look at Erson or Jesel then call both of them tell them what you are trying to accomplish and ask for their suggestions. We used Erson with a .225 offset to get the proper pushrod geometry. They work and only took about 3-4 weeks for them. Fed:&7
Old 12-17-2016, 02:43 AM   #3
ss3011
ss3011's Avatar
I was hoping there was an off the shelf lifter , that someone was currently using . Someone else must be having the same problem of galling the ends of pushrods that I am having .
Old 12-17-2016, 11:21 AM   #4
FED 387
Have u talked to Trend about your problems
Old 12-17-2016, 11:37 AM   #5
V M Kauffman
Your problem might go away if you used the correct engine oil!
V M Kauffman is offline   Reply With Quote
Old 12-17-2016, 04:36 PM   #6
Ed Wright
Ed Wright's Avatar
Mine is not Chrysler, but my Isky RedZones were doing that to intake pushrods at the rocker. If yours is also hurting them at the rocker, this may help: My lifters had an oil hole just above the band machines around the lifter body. I used a 3 cornered file to add a small groove from that band, up to the oil hole. Simply put a little more oil up the offending pushrods. My intakes only hurt pushrods, but they were 1.8 ratio, my ex were just 1.55. Hope this might help yours.
Ed Wright 4156 SS/JA
Old 12-17-2016, 07:01 PM   #7
ss3011
ss3011's Avatar
Most of the Chrysler lifters have no band , and no holes drilled for any flow to the pushrod seat . Jesel makes a keyway lifter, that will oil through the pushrods, to work in a Hemi , but with the bushings, and all the machine work , it gets real pricey . If someone made a lifter that was similar to the way a Chevy lifter works, but for a Hemi , then that would solve the problem . Then a guy could buy hollow style pushrods , and oil the rocker balls directly through the pushrods. That is what I am looking for.
Old 12-17-2016, 08:01 PM   #8
sugar1366
Try MRL Performance. I've got a set in a small block with jesel rockers- don't even have to bush the block.
Eddie Bolton
sugar1366 is offline   Reply With Quote
Old 12-17-2016, 09:31 PM   #9
ss3011
ss3011's Avatar
Eddie Bolton
Thank You very much , As indicated on their website , it looks like exactly what I am looking for . I will give them a call on Monday !
Old 12-17-2016, 11:18 PM   #10
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
The AMC lifter used in a BB Chrysler will oil through the pushrods.
Paul Precht is online now   Reply With Quote
