Old 12-21-2016, 11:15 PM   #1
joe huestis
Liked 411 Times in 114 Posts
Question Electric radiator fan recommendations
Shopping for an electric cooling fan for my '78 Camaro stocker with stock size radiator. What size, cfm rating, and amperage would be sufficient for adequate cooling ? Curved or straight blades ?
Joe Huestis
Youngsville, NC
Old 12-22-2016, 12:44 PM   #2
terry1
Liked 24 Times in 13 Posts
Smile Re: Electric radiator fan recommendations
Joe, I have the same car as you. I use a Flex-a-lite fan # 118. 2500 CFM.
Works good for me. I do not use a shroud, for no particular reason.
18 Amp draw, be sure to use a relay.
Terry Knapper
terry1 is offline   Reply With Quote
Old 12-22-2016, 07:33 PM   #3
joe huestis
Default Re: Electric radiator fan recommendations
Terry, thanks for the reply. What combo do you run ?
Joe Huestis
Youngsville, NC
Old 12-23-2016, 09:09 AM   #4
Shaun Quill
Liked 105 Times in 26 Posts
Chevrolet HHR from your Chevy parts department is a nice one. It has a built in shroud. It fits my 68 Camaro like its factory but your radiator is probably wider
Old 12-23-2016, 09:09 AM   #5
terry1
Joe, I run the 175/275 HP, 350 CID in "I" trim. Stick setup.
I run my car as a coupe. The Z28 is to heavy to be a natural "I".
Terry K
Old 12-23-2016, 10:17 AM   #6
Dave Ribeiro
Liked 56 Times in 27 Posts
Joe , you have a PM............
Dave Ribeiro 1033 STK
Old 12-23-2016, 10:53 AM   #7
joe huestis
Thumbs up Re: Electric radiator fan recommendations
PM back at you Dave and Terry you have a PM.
Joe Huestis
Youngsville, NC
Old 12-23-2016, 10:56 AM   #8
joe huestis
Shaun,
I own a 2011 HHR as my daily driver. That's an idea. Hmmm...
Joe Huestis
Youngsville, NC
Old 12-23-2016, 08:26 PM   #9
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Terry Knapper
Why is a relay needed? Just curious, I've never used a relay, just a toggle switch and an inline fuse.
Mike Moller
NHRA 203 Q-R-T/SA
Old 12-24-2016, 08:51 AM   #10
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
It's a lot of amps to pull thru the switch. The wire can get real hot. This way the switch only triggers the relay.
U/SA
79 Mustang
