Old 12-23-2016, 07:12 PM   #1
Birch motor cars
Liked 3 Times in 1 Post
Default Back seat
Can someone tell me if you are required to run a back seat in Stock Eliminator ? Can you run a mini tub as well ?
Birch motor cars is offline   Reply With Quote
Old 12-23-2016, 07:14 PM   #2
David Lee
Liked 346 Times in 126 Posts
Default Re: Back seat
if you have a roll bar no and mini tub no
Old 12-23-2016, 09:47 PM   #3
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
If you install a roll-bar or -cage, and if you're running any stock class "M" or above you're required to do so, you can remove the rear seat. You have to carpet the area where the seat was installed to finish the installation.
As David mentioned, modifying the inner wheel-wells with a "mini-tub" is prohibited, although you may be able to gently "massage" certain areas to get enough clearance.
Lew Silverman #2070
"The Wagon Master" N/SA
Old 12-23-2016, 11:03 PM   #4
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
You shouldn`t need to mini tub much anyway. You`re only allowed a 9" wide slick.
Lane Weber
Old 12-24-2016, 11:30 AM   #5
Birch motor cars
Smile Re: Back seat
Thanks guys, I bought an 68 Camaro ex stock eliminator car with no motor. I have pictures of the car running in Stock. My car is mini tubed and has no back seat but it's all finished off with carpet. It ran in IHRA G/CM. We have installed a small block 400 in the car to get some seat time with the car first. Our goal is to race Stock. All input would be appreciated.
Old 01-05-2017, 04:03 PM   #6
Timetraveler
Liked 12 Times in 6 Posts
If you run in a class lower than M and don't need a roll bar but you run a fuel cell and need a fire wall do you still need a back seat?
Timetraveler is offline   Reply With Quote
Old 01-05-2017, 05:03 PM   #7
GUMP
Liked 2,361 Times in 558 Posts
The IHRA allows mini tubs. The NHRA doesn't.
GUMP is online now   Reply With Quote
Old 01-05-2017, 05:45 PM   #8
Lew Silverman
Basically, yes, without a roll-bar or -cage you still need to have your rear seat in place.. The bulkhead that the rear cushion attaches to normally serves as the fire-proof barrier for a fuel cell installed in the trunk. The seat itself doesn't effect that function.
Lew Silverman #2070
Old 01-05-2017, 06:08 PM   #9
Timetraveler
Thanks Lew. I did put a firewall in when I changed to a fuel cell in the 66. If I need to I can still get the back seat in.
