Old 01-09-2017, 05:58 PM   #11
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: Mikronite vs REM
Originally Posted by Jim Bailey View Post
Dan, the best results we had were with the Pinion Depth slightly deeper than recommended, into the ring gear, then making sure the backlash was set a the tightest spot you can find rotating the ring gear. "IF" then the backlash seemed too lose the rest of the rotation, we didn't worry about it. The only time we got into trouble was with the set up being too tight. My guess is the Cryo'd and Rem'd gear sets don't "wear in". For lube we always ran 75/90 synth. keeping in mind that we always ran max capacity. None of that 1/2 to 1 quart B.S. Your ring and Pinion is a very high load area in your race car that requires lube at all times. Not saying this is right, but it worked for me ... hope it helps.
YEAH it does actually. Mine is filled.
The SS uses a 8.5 Rear 10 Bolt which is a strong rear.
Full Stock figure you would need the 12 bolt 8 3/4 rear.
Might add a heater to keep it warm.
D
Old 01-10-2017, 02:59 PM   #12
340Cuda
Liked 805 Times in 341 Posts
Who are some of the vendors you all have had good luck with treating ring and pinions?
Thanks,
Bill
Old 01-10-2017, 07:36 PM   #13
Greg Barsamian
Liked 427 Times in 97 Posts
I used Performance Engineering & Manufacturing.
Charged $164.00 total to do both Cryo & REM treatments.
Turn around time once they received the ring & pinion was 14 days.
Contact Randy to get a CN number for any parts you send to their plant.
Randy Harrison: rharrison@pemracing.com
Performance Engineering & Manufacturing, LLC
425 Industrial Park Drive
Saint Clair, MO 63077
ph; 636 234-0975
fax 636 234-0982
www.pemracing.com
Old 01-10-2017, 07:57 PM   #14
Jeff Stout
Liked 708 Times in 285 Posts
Any other places to send here on the west coast AZ area? Thanks Jeff
Old 01-10-2017, 08:09 PM   #15
Jim Bailey
Liked 584 Times in 94 Posts
Thumbs up Re: Mikronite vs REM
Contact Terry at Earp Machine in Safford, AZ. They do a great job with quality equipment.
Jim Bailey is offline   Reply With Quote
Old 01-10-2017, 11:21 PM   #16
Jeff Stout
Thank you. Getting ready to change gear on my hot rod for 1/8 mile racing.
