Old 01-30-2017, 09:57 AM   #11
jmoneyfoot
Liked 9 Times in 5 Posts
Default Re: Spark Plugs with Two-Step
Off subject but where do you get a less than 3000rpm 2 step chip? TIA
jmoneyfoot is offline   Reply With Quote
Old 01-30-2017, 12:18 PM   #12
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
With the EFI systems, you just type in any RPM you want and it takes care of the rest. I'm not sure who sells chips that go down to 3000. Don't have anything that low in the super stocker that's for sure!
'65 Mustang SS/L & L/SA
Bobby Fazio is online now   Reply With Quote
Old 01-30-2017, 12:39 PM   #13
Rsmith38
Liked 28 Times in 15 Posts
MSD makes an adjustable module which goes down below 2000 - plugs in like chip - I have mine set at 2800 for launch.
Rsmith38 is offline   Reply With Quote
Old 01-30-2017, 12:46 PM   #14
Rory McNeil
The low RPM chip that MSD sells is red, and it comes with a small slot blade screwdriver that is used for adjusting the limiter RPM screw located on the side of the chip.
NHRA 6390 STK
M/S 85 Mustang
Old 01-30-2017, 04:31 PM   #15
Ed Wright
Ed Wright's Avatar
Bobby, I use the 8670 MSD adjustable RPM module. Has a lead that plugs into my MSD box where the chip would plug in. Goes down to 3000 RPM, turn the knob to select RPM, in 200 RPM steps.
Ed Wright 4156 SS/JA
Old 01-31-2017, 01:57 PM   #16
Barry Polley
Guest
Posts: n/a
Biondo sells a push button below 3000 setup. Nice. Used it for years.
Old 01-31-2017, 04:57 PM   #17
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
https://www.msdperformance.com/produ...ols/parts/8735
Bob Mulry 7516 STK
A & M Motorsports
Old 01-31-2017, 11:42 PM   #18
Jeff Blanchard
I did not see any mention of open or closed loop. Maybe if stayed in open loop on 2-step, could keep from adding unwanted fuel, and then go to closed loop very soon after releasing brake. You would have to be close on your fuel map. Also, you might consider talking to the tech line guys at NGK. I have found them easy to get a hold of, and very knowledgable. I have always been impressed with the quality of NGK plugs.
Jeff Blanchard
353C / Stock
Jeff Blanchard is offline   Reply With Quote
Old 02-01-2017, 11:33 AM   #19
Ed Wright
Ed Wright's Avatar
You most certainly do not want it in Closed Loop on the 2 step! Only at WOT. If you use a FAST XFI, there is a delay after start up you select in the Closed Loop enable paramaters, I don't remember how many seconds my delay is set to now, but it goes in Closed Loop part way into first gear. Some time after the launch.
I have had to replace so many new NGK spark plugs to cure misfires in customer's vehicles on my dyno, when my shop was still open, that I won't use them. I have had fewer problems with Autolite spark plugs than any others.
Old 02-01-2017, 11:42 AM   #20
Bobby Fazio
FAST goes into open loop automatically whenever the two-step is activated. I have closed loop pretty much turned off at high rpm high load. I only use it around the pits to keep the plugs clean.
What are your thoughts on irridium vs platinum vs copper?
