Old 02-05-2017, 02:19 AM   #11
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Default Re: MSD 2 step issue
Originally Posted by Bob Mulry View Post
You have a PM.......................
Hi Bob, I didn't get it. Thanks.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 02-05-2017, 08:13 AM   #12
Mike Jones
Liked 684 Times in 289 Posts
Originally Posted by John Nechiporchik View Post
Thanks Jim. I'll do as you suggested as I don't see any other options with my current configuration. I'm still perplexed as to how the MSD will intermittently activate without power to the circuit. MSD tech has no answer. They did suggest I could send the box in for testing....but indicated due to it's obsolete status, they could not repair it. Rather absurd suggestion. That advise was after waiting 35 minutes on hold on the tech line.
Thanks again Jim. The toggle switch comes out tomorrow.
John
Does MSD manufacture in China?
Thanks
Mike A114
P/SA
Old 02-05-2017, 09:44 AM   #13
Bill Grubbs
Liked 564 Times in 66 Posts
In America...almost all in El Paso, TX.
Bill Grubbs is offline   Reply With Quote
Old 02-05-2017, 04:15 PM   #14
jimmyparker
Liked 309 Times in 88 Posts
I had a new MSD coil tagged made in China, shocked to say the least.
jimmyparker is offline   Reply With Quote
Old 02-05-2017, 04:42 PM   #15
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
My bad......
That PM was for John.....
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 02-05-2017, 05:47 PM   #16
Timetraveler
Liked 12 Times in 6 Posts
I have my two step wired like you do. One wire thru a toggle switch next to my shifter and connected to my brake lite switch, which is adjustable. I have hundreds of runs on it with no problem. The only way it could activate with the switch off is if the wire shorted to ground before your toggle switch.
Timetraveler is offline   Reply With Quote
Old 02-05-2017, 05:59 PM   #17
Adger Smith
Liked 880 Times in 311 Posts
Or a ground feed back activation.
Adger Smith (Former SS)
Old 02-06-2017, 10:01 AM   #18
John Nechiporchik
Liked 13 Times in 7 Posts
Hello All.
Since my original post( last June), I changed the MSD box (Digital 7) and the intermittent 2 step problem went away.
I contacted MSD several times and they said the old box could not be repaired.
I left the on/off switch in place as I have become comfortable with it as part of my routine.
John
John Nechiporchik is offline   Reply With Quote
Old 02-06-2017, 03:08 PM   #19
BWill
This question is for Mr .Parker, what kind of pressure switch are you talking about and where could one be purchased?, Thanks
BWill is offline   Reply With Quote
