Old 02-09-2017, 10:45 PM   #1
STR001
Default Carburetor Recommendation
What is the required carburetor for the 305/175 hp engine 85 Camaro (H/SA)? Any aftermarket carbs that are legal? Any recommendations on a good carb? Thanks, Jason
STR001 is offline   Reply With Quote
Old 02-10-2017, 08:58 AM   #2
kansas stocker
Liked 250 Times in 49 Posts
Default Re: Carburetor Recommendation
Check Dwight's site www.classracerinfo.com.
Register and then use the technical tools section.
Should tell you what you need to know.
Remember that you can use any carburetor of the same type and size.
It does not need to be of the correct year.
Pete
kansas stocker is offline   Reply With Quote
Old 02-10-2017, 09:09 AM   #3
Brian Fink
Liked 28 Times in 9 Posts
You will save yourself some time and the possibility of a bad decision by calling Dean Oliver ( Deano's Carburetors) .He will set you straight !
Brian Fink is offline   Reply With Quote
