Old 02-15-2017, 03:10 PM   #11
carl hinkson
Liked 18 Times in 10 Posts
Default Re: Lightest solid roller lifter
Originally Posted by Hacksaw View Post
Some of this may be self inflicted. 1st one was a Crane in my Comp motor, the last two were in SBC Superstockers, a Comp Cams and a Crower Hi-Po. .894's in the SS. Soooo your thoughts on how many runs are safe and what about a needle lifter making more power than a bushed.
Those lifters mentioned if you are putting them in a .844 lifter bore they are to small.
Comps, Crowers and ISKY"s are .8405 to .8415 in that area and to put them in a GM lifter bore that is .844 and more so on the old blocks with short lifter bores. Running lifters in a bore with .003 clearance lifters are not happy and will show it as they looked scuff because they are using the bottom of the lifter as a cutting tool.
Morel seems to be to OEM size whether its a .842, .874 or .904
When machining for roller lifters I measure I measure each lifter and make sure bores are machined accordingly.
Here is a good link on lifters sizes between companies.
Here is a thread I saw a while ago
http://www.offshoreonly.com/forums/g...ifters-10.html
carl hinkson is offline   Reply With Quote
Old 02-15-2017, 03:30 PM   #12
Hacksaw
Liked 312 Times in 175 Posts
Thanks Carl. Next move will be to a .904 lifter. Does Morel offer needle and bushed? Which do you prefer?
Old 02-15-2017, 03:36 PM   #13
carl hinkson
If your going to a .904 and they are fitted .0014 to .0019 oil clearance I would go with a needle to date any .904 Morel I have sold or customers have sent me has had zero problems. Bigger body, bigger wheel and bigger axle. They also are an Ultra Pro lifter which has pin oiling.
They do offer bushed as well.
My feeling on the bushed lifter is the jury is still out on those I have had some interesting calls about bushed lifters in the last year or so.
Good Luck which ever way you go.
Old 02-15-2017, 03:36 PM   #14
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Originally Posted by randy wilson View Post
Has zero bearing on performance. What good would it do to have a light weight lifter, and attach 1/2" pushrods to them? Stability, and accuracy on that side of the valve is far more important.
Nothing wrong with reducing weight , 1/2" pushrods are there to improve the stiffness of the system . Lifters are already pretty stiff , so reducing weight without compromising durability is probably OK .
Old 02-15-2017, 06:39 PM   #15
ron mattson
Liked 68 Times in 31 Posts
Weight of anything that moves matters,
With that being said strength and durability
are first then look for weight reduction. Not
roller stuff but there is up to 50grams each
weight difference between the heaviest and
lightest hydraulic/solid lifters, not as much in
pushrods but there is a difference,you don't
need baseball bat pushrods in a stocker with
400lbs open pressure.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 02-15-2017, 07:54 PM   #16
randy wilson
Liked 22 Times in 22 Posts
There is nothing wrong with it, It just ain't as important on that side of the valve. It's OK. It just ain't to be obsessed over.
don,t have one
Old 02-15-2017, 09:53 PM   #17
Ed Wright
Ed Wright's Avatar
Yes, wrong end of the rocker to sweat weight that much.
Ed Wright 4156 SS/JA
Old 02-16-2017, 12:07 AM   #18
James L Miller
Liked 25 Times in 16 Posts
My engine guy in Tampa ran into that issue with the .904" lifters in Mopar engines. He said the lifter bores were originally .9050" to .9058". The lifters were .9040"-.9045".. Now the lifters tend to be sized for a .904" bore. He finds a lot of leakage of oil like what was in that video.
Mopar 2 Ya!
