Old 02-17-2017, 05:57 PM   #11
partsbob67
Liked 79 Times in 11 Posts
Default Re: 12 bolt gear oil
Beware of the redline stuff. It has changed since they were bought out.0
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 02-17-2017, 06:20 PM   #12
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
I have 5 Gallons of the old Heavy Shockproof (Red) if anybody would want it ... Never opened ... Back when we were going through 6.00 gears every 50 runs, I tried this . It did help .... But a 9 in. was the cure ....
Jeff Niceswanger 3740 SS
Old 02-18-2017, 08:57 AM   #13
Todd Hoven
Guest
Posts: n/a
I wonder if anybody has ever tested oil level in a 12 bolt. I think that your better to have a slight over fill then an underfill condition. If there is not enough oil then the gear runs dry and you create friction. I can't imagine there is much ET between running 1 and 2 qts. That's just me
Old 02-18-2017, 11:31 PM   #14
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
The gears will not run dry with 1 qt. My only concern would be the axle bearings. Sounds like 1 qt is what many use.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 02-19-2017, 08:16 AM   #15
james schaechter
Liked 1,439 Times in 301 Posts
I have used the redline lightweight and super lightweight for years and love it. Rear and stickshift transmissions.
Please explain what has changed and what I should be concerned about? Did I miss a memo?
James Schaechter 3163 STK
Old 02-19-2017, 11:51 AM   #16
cad
cad's Avatar
Liked 93 Times in 52 Posts
I have 2 qts of Richmond GL-5 in my 12 bolt, and put 220-240 runs a season on my pro gears. I think these gears have been in for at least 4 seasons.
Clark
Old 02-19-2017, 12:39 PM   #17
Darrel, This has been discussed here before,..several times.
I've run 1 qt. 85-90 synthetic, quite a bit ,and never hurt anything.
The cover design on a 12 bolt, directs oil right to the side bearings anyway.
That being said, it's been determined by several racers, that a lot of the oil goes up into the axle tubes anyway, and that 2 qts. won't hurt you much.
A personal observation: If you are going to try some kind of super light concoction for a record run or something, make sure the gears are well broken in with the regular stuff first.
Old 02-20-2017, 01:03 AM   #18
Darrel Goheen
Thanks for the info.
Old 02-21-2017, 06:32 AM   #19
Greg Barsamian
Liked 427 Times in 97 Posts
I would like to know about your findings as well?
Old 02-21-2017, 10:18 AM   #20
Eman
Liked 133 Times in 76 Posts
2qts should be just right. As far as axle bearings go on axles like a Ford 9" the seal is in the tube behind the bearing from the factory. I can't remember how it is with c clip eliminators. I never saw the advantage of the heavy shockproof in a rear. I prefer flow over it sticking to non wear parts. It's impressive if you disassemble as gar as how it coats everything.
As far as support goes I don't think anyone holds a candle to Lucas for support and their products are great. I like Lucas synthetic gear lube.
