Old 02-21-2017, 11:55 AM   #1
Ryan_Haag
Ryan_Haag's Avatar
Liked 8 Times in 3 Posts
Default Garage Sale!
MSD 7AL2 - this was our spare box. Used it this winter. $275 OBO
MSD Pro Power Coil Part #8201. Brand New never used. $150 OBO
Manley 221448-16 Used valve springs, 10 degree Titanium Retainers, OD Spring Cups. Has 74 drag race runs. Tested with (Rimac Tester) now 325# @2.100" $300 OBO
Rossler Valve Body, Full Manual, Reverse Pattern PRN123, Chevy, TH400, Removed from Rossler TH-400, replaced with clean neutral valve body reason for sale! This is in like new condition with all hardware need to install and with instruction sheet. Air Shifter also available. $175.00 OBO
Hurst Quarter Stick II Shifter for turbo 3 speed shift with solenoids and cable. Complete hands free shifting. Select each RPM for each gear shift!
Also includes ADC Shift Control Box.
Upgrades any single RPM CO2 shifter for Turbo Action & any other single solenoid (A & E, Biondo, Dedenbear etc.)
Allow 1-2 and 2-3 shifts at different or the same shift point
Box shuts off after the 2-3 shift for users wanting to go for a clean neutral.
Using in my Super Stock car now, works perfectly. Won US Nationals @ Indy this year using this shifter,changing because of different transmission for 2017 race season! $350 OBO
Strange pro gear 9" Ford. 5.67 ratio lightened. 54 runs on gear. Asking $250 OBO
Ultra Strange Center Section with Billet aluminum caps, Mark Williams light weight spool, Billet aluminum tapered pinion support, Strange lightened 5.43 gear, chrome moly 1350 u-joint. 57 runs on complete center section. Asking $1500 OBO
Chevy 434ci 750hp
Shafiroff short block
Chevy Bow tie block
Jeff Johnson alum.oil pan
System 1 oil filter
Jesel belt drive
Jesel rocker arms
Msd front drive distributor
Msd crank trigger
Edelbrock super victor
Demon carb.
AFR heads
Alum.valve covers
All it needs is push rods,water pump ,starter
DYNO time only!
SOLD!!!
Call or Text
Ryan Haag
502-727-1035
Ryan Haag
SS/EA 3750
E/SA 3750
Ryan_Haag is offline   Reply With Quote
Search this Thread:
Advanced Search
