Old 02-21-2017, 10:39 AM   #11
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: question for EFI guys
Save yourself money and aggravation...
http://www.russellperformance.com/mc...wist-lok.shtml
Rich Taylor
I/SA - 321
Old 02-23-2017, 09:46 AM   #12
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
thanks guys, think I've got it under control now...can't bring myself to use twistlock on a high pressure system though...
Old 02-23-2017, 11:11 AM   #13
HandOverFist
Can't make a twistlock leak Tom. I have however seen braided line connectors leak due to improper assembly. You will be fine either way.
Rich Taylor
I/SA - 321
Old 02-23-2017, 11:17 AM   #14
Tom keedle
Tom keedle's Avatar
more worried about if it would go to deadhead pressure for some reason and having it blow off...I've been on fire before
Old 02-23-2017, 11:27 AM   #15
HandOverFist
Just from experience I think it would be more likely the hose would rupture before it came off the fitting in any scenario...impossible to pull one off, must be cut.
Rich Taylor
I/SA - 321
Old 03-21-2017, 12:28 PM   #16
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
Rich, do you think that hose is legal to use from pump in trunk to engine compartment ? I thought metal or steel braided was required.........
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 03-21-2017, 02:41 PM   #17
HandOverFist
Pretty sure it is NHRA approved. Mine is protected/shielded in the flywheel area.
Confirmed - pg 97 http://promod.nhra.com/userfiles/fil...edProducts.pdf
Rich Taylor
I/SA - 321
Old 03-21-2017, 07:03 PM   #18
GallopinGhost
Thanks. Prices are all over the place for braided line. I'll check out the russel stuff.
Brian Carpenter
Stock 1358
