Liked 69 Times in 30 Posts
If I ever hear of a race car or trailer stolen I will say it's your fault and nobody else. I've written about GPS trackers before and now there is no reason not to own one, the best and cheapest is call TrackR. This the cheapest $19 to $25 no fees from your cell phone. Company just an app on your cell. This device can be hidden anywhere in your race car and best of all it can't found with a cell tracker that most thieves are using. I've bought one for all my equipment and I've tested and it works.CR
Liked 706 Times in 283 Posts
I thought these worked off of bluetooth on your phone. When Trackr is far enough away from phone its disconnected. If the Trackr is near someone elses phone and and they have the app downloaded then they can track your Trackr until its out of their bluetooth distance. Am i wrong?
#3 | |
#4 | |
Liked 21 Times in 3 Posts
SO do you need to be within Bluetooth range for the app to locate the receiver?
Liked 805 Times in 341 Posts
From live chat on TrackR website:
The maximum bluetooth range for our TrackR devices is up to 100 ft. or 30 meters (clear sight). Within this 100 ft. range, the item is located on a map using Google Maps or iMaps data from your phone. Range will vary depending on line of sight. Indoors the range is 30-50+ feet. ****PLEASE NOTE: TrackR is NOT a live GPS tracking device.****You will not see live or real time movement**** If your device is lost or is outside of this bluetooth range (up to 100 ft.), you will need to rely on our Crowd Locate network to locate your items. When an item goes missing with a TrackR device attached, anyone with the TrackR app installed on their phone will begin to search for that item. When another TrackR app user passes within 100 ft. of the lost item, that user's phone will anonymously ping our server and then you will receive an update with the new time, date and location. You can see a map of Crowd Locate coverage at http://www.thetrackr.com Just scroll down to the middle of the page and type in your address in the address field above the map to see your coverage. Important note: Because Crowd Locate does depend on another TrackR app user coming within bluetooth range of your TrackR device, we have no control over when that may happen. So, please make sure you do check your Crowd Locate coverage if you want to use TrackR on a pet or a valuable item like a bike or car, etc. |
Liked 70 Times in 31 Posts
The TrackR has no GPS.
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
#8 | |
Any good thief has a good cell phone signal jammer.
Liked 101 Times in 52 Posts
