Old 02-26-2017, 06:30 PM   #1
oldskool
oldskool's Avatar
Liked 748 Times in 363 Posts
Default Current GM Q-jet Rules
Please excuse this Dummy question. But, I just wanna get this straight in my mind.
In the Class Racer Info guide, I see that for many engines there are a couple of numbers listed for legal factory carbs, and either a 1901 or 1903 Edelbrock Q-jet, depending on whether the engine came with what we call a 750 or an 800 Q-jet. It appears that they are separated by their max allowable venturi size. So, for this post I'll just refer to 'em as a "big" or "small" carb.
So here are my questions:
(1) Have these rules been changed, or relaxed, to allow ANY small carb, for any GM engine that came with a small carb, and ANY big carb for any engine that came with a big carb ? Again, I realize that no carb can have a larger venturi size than what is listed as legal, for the engine.
(2) If the answer to #1 is no, then exactly which replacement Q-jets are legal ?
For example: Can you use a different number carb, from your engine brand, but not from another GM brand ?(such as a side inlet Chevy carb instead of a BOP front inlet carb)
And for the big carb engines, can you use any big E-carb, or just the 1903 ?
http://www.carburetion.com/Rochester.asp
Old 02-26-2017, 06:43 PM   #2
J.R. Haddad
Liked 1,471 Times in 308 Posts
Default Re: Current GM Q-jet Rules
Casting number of the carb no longer matters, measurements do. J.R.
J.R. Haddad is offline   Reply With Quote
Old 02-26-2017, 06:52 PM   #3
oldskool
oldskool's Avatar
OK, thanks !
That brings up more questions. Since this info is not mentioned in the Class Racer Info guide, exactly when did this new rule go into effect ?
Is the rule only mentioned in an official NHRA rule book, or is there another source I can find online, if I know the correct link ?
Old 02-26-2017, 07:15 PM   #4
Liked 5,154 Times in 1,967 Posts
OK, thanks !
It's not a new rule, by any stretch. Been this way for 20 years...Probably more
Old 02-26-2017, 07:32 PM   #5
oldskool
oldskool's Avatar
OK, just going by what I read in the Class Racer Info guide. If I'm reading it correctly, there is no mention of the fact that any Q-jet that is within the legal venturi size is OK.
So, another question: Does an Edelbrock Q-jet have any advantage over a GM Q-jet ? Or, can the good Q-jet builders get the same power potential from either, just as easily ?
Old 02-26-2017, 08:43 PM   #6
J.R. Haddad
I think that would be a question for the good quadjet builders. J.R.
Old 02-26-2017, 08:53 PM   #7
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
The tech sheet info on Class Racer Info is obtained from the NHRA Tech Sheets. Neither do the NHRA Tech Sheets or rule book specifically describe the situation you are questioning. There is a statement under the Carburetor paragraph of the Stock Cars section of the rule book that states "Replacement carburetors permitted provided they are same model, type,throttle bore, and venturi size." The provision for using Qjet carbs apparently falls under that statement.
Dwight Southerland is online now   Reply With Quote
Old 02-26-2017, 08:58 PM   #8
older racer
Liked 68 Times in 26 Posts
hello, question? does the inlet have to be the same location? on any carbs? just curious. thanks
older racer is offline   Reply With Quote
Old 02-26-2017, 09:08 PM   #9
No
Old 02-26-2017, 09:52 PM   #10
oldskool
oldskool's Avatar
OK. I reckin the words "same model, type" just mean they have to be a Q-jet type carb, and not necessarily a Chevy Model, or Buick model, or whatever car brand you race, or one specific Edelbrock number.
I suppose it only matters how the tech guys interpret the rule. It makes sense to me, since I don't see any big advantage to a particular Q-jet. But then there are lots of very similar parts, from different year cars, that would not provide an advantage, but are not legal.
Don't know if more of these similar, but different year parts will become legal, as parts for the older cars become more scarce, or not. ?
