Old 02-28-2017, 05:30 PM   #1
rod
Liked 20 Times in 15 Posts
Default O2 ?
my O2 sensor is 8 1/2 inches from the end of the collector. Is that too close? I can make a collector extension [might help low end, so that would be a +]-if so, how much longer? or will it be OK as is?
this is the only place it can be, so I can't move it to a more favorable position
thanks
Rod in AZ
rod is offline   Reply With Quote
Old 02-28-2017, 09:22 PM   #2
Timetraveler
Liked 12 Times in 6 Posts
Default Re: O2 ?
Rod your O2 needs back pressure to work. I don't believe in using an O2 gauge to dial your car but it can save your engine if your going lean at high rpm. Do your testing with a long extension or a muffler and get your reading. Then run your extensions with a paint stripe and cut at the end of the paint burn. 'OLD SCHOOL'
Timetraveler is offline   Reply With Quote
Old 02-28-2017, 11:42 PM   #3
Ed Wright
Ed Wright's Avatar
Default Re: O2 ?
thanks
Rod in AZ
They do not need back pressure. That is, however, closer to the end than I would run it. I put mine right at the end of the transition. That is only good for WOT. To use the O2 for part throttle (I.E. return road) you need an extension. A muffler works well, or a 24" extention. I have a 24' with a 45 deg bend about half way. Reversion during the overlap cycle will pull clean air back in at low RPM & loads. Looks very lean on the O2. Works OK @ WOT.
Ed Wright 4156 SS/JA
Old 03-01-2017, 01:46 AM   #4
Bruce Fulper
Liked 54 Times in 33 Posts
Default Re: O2 ?
Does NOT work. Never did. You can cut your way all of the way to the cylinder head. Air changes. Not a reliable test. Leave it where it's at. You're making your own relationship to any changes anyway.
Bruce Fulper is offline   Reply With Quote
