#31 |
Liked 28 Times in 11 Posts
Rule needs to change period. Starters discretion? So spend your hard earned money and he will tell you how your driving style should be based on "HIS" interpretation??
It sounds like it to me!
EX 5-Doorstocker |
#32 |
Liked 783 Times in 195 Posts
However, immediate discretionary calls are common in all kinds of sports. Standards and clear rules are necessary, and an official should be at the place of action. Maybe we need a line judge and instant replay? The nature of such sports related calls always makes for controversy. This is a good time to review rules, process and procedure.
#33 | |||
Liked 13 Times in 9 Posts
On the recent WFO Podcast, Division Director Mike Rice quoted the rule and then went on to say he thinks it should say or mean something else. While I agree that the rule does not go far enough, it does not matter what I think or Mike Rice thinks, or anyone else. The rule says what it says. If NHRA does not like what the rule says, then they should change the rule. If NHRA's rule read the same as IHRA's rule on the subject, they *might* have a leg to stand on. Under "Grounds For Disqualifications", it states: Quote:
As I have said before, In my personal opinion, NHRA's rule doesn't go far enough, and NHRA's ruling went too far! There is a LOT of space between the two. They either need to rewrite the rule and start DQ'ing a LOT of drivers this year, or apologize and make amends with Mr. Emmons. There is a completely separate issue here that is being largely ignored. There is a problem with Emmon's car, and he is aware of it. On the WFO Podcast, he said that after one of the runs where it smoked the tires and got sideways on him, they took all the wheels off the car and had the brakes inspected by a well-known chassis builder. While they did not find an obvious issue, the car continues to not stop the way they would like it to. When Thomas Fletcher had his dramatic 360 spin a couple of years ago, Dan inspected the car and found a problem with the brakes, and fixed it.
#34 |
Liked 224 Times in 87 Posts
The video shows he rolled down the window in the shutdown area and waved his hand out the window (safety no no). Thats something I got the never do that again speech for ... Any how good driving , maybe hold alittle less ...
#35 |
Liked 5,145 Times in 1,964 Posts
Again, not putting forth my opinion, because I wasn't there.
Video? I've had two people say it looks like Emmons' back wheel comes off the ground. I did see the video of round two. I wonder if some of you did? We know that he received a warning after that one. We know that ,in the fourth round, he was down 10 mph and still ran .02 under the dial. The starter says he saw an unsafe movement of the car , from his vantage point. They have to be able to make a discretionary call when it comes to safety issues, in MY opinion. Should NHRA have said..well, he didn't hit the wall, or the other car, so let's wait until maybe he does? Can you imagine the liability on that one? Yes, I like the IHRA rule much better. No, I don't think there was a vast West Coast conspiracy here.
#36 |
Liked 100 Times in 51 Posts
There is one thing we all can agree on, "Excessive" braking is a bad thing. We have all seen crashes resulting from excessive braking.
I have spent quite a bit of time researching this story. I've looked at the NHRA All-Access video. This is truly a case of an official making up for a missed call on an earlier incident. Just like in baseball, where the umpire calls a ball instead of a strike on one pitch, then evens up the count on the next pitch, regardless of where the ball is thrown. In R1 Jerry smoked the front tires at the stripe. In R2 he got the car turned sideways so hard the announcer comments about seeing both sides of the car at the stripe. R3 there was no mention or clear video evidence of anything unusual happening at the stripe. In R4 Jerry is DQ'ed. This is really a bad decision (for R4) because it probably should've happened in R1 or R2. I say a bad decision because it changes how eliminations continue with the wrong person not being able to continue. Everything is messed up, points, money etc. Now Jerry says that he won't let NHRA dictate how to drive his race car. Now we have a challenge, NHRA says one thing, Jerry says another. I wonder who will prevail? I believe NHRA will begin a big push to enforce their rule about "unsafe driving. It needs to be done, and done equally. Dan Foley SC4698 |
#37 | |
Liked 502 Times in 130 Posts
Eric Merryfield 1883 STK |
#38 | |
And I agree that sometimes its excessive braking because the driver stomped two feet on the pedal and tried to throw the car in park, and sometimes things happen because of mechanical issues and that can cause the car to wiggle, premature lock up the tires, etc. I would hope that if it's a mechanical issue NHRA would make up for it somehow, but it is NHRA after all.
Updates on the Tax Bracket Racing Team |
#39 |
It appears to me that racers are dialing soft with the full intension of hitting the breaks at the end of the run. If that is the plan then plan on getting tossed. They should dial closer to what they can run so this is not an issue. They know what their car will run.
Dan
Dan Wilson, STK3171, K/SA |
#40 |
That is how it works Dan with the top notch drivers.
Tony Janes 7941 STK, SS |
