Liked 28 Times in 15 Posts
Got a 2007 GMC 1500 I bought new, it now has 248K on it and has developed a intermittent ticking noise on the drivers side. I was told it was a rocker arm that needed to be replaced. Anybody seen this issue? Should I isolate which rocker it is and replace it or is there more to the problem? Otherwise great vehicle, can park a 10 year old truck on the driveway and it doesn't leak a drop of anything. Thanks in advance.
Liked 719 Times in 220 Posts
When I worked for the city of Los Angeles, our fleet had a lot of those trucks. A few of them developed rocker noise like you described. Isolate the rocker and remove it for inspection. They are roller rockers, sometimes parts get loose.
I have two sets of heads I bought with rockers on them so I have a bunch. If I remember installing a rocker on these engines involves only a torque setting when tightening them correct?
Liked 43 Times in 29 Posts
Sad to day you may have a worn camshaft. Have seen a few in the dealership with a top end tick noise.
Mark Ruset 2048 STK |
Liked 333 Times in 180 Posts
GM had a bulletin # PIP4499B regarding lifters also u might check oil pump O ring over time (yours is old 248K and 10 years) they get hard and do not seal properly allowing air to pass thru the system and causing intermittent oil pressure very common in 5.3 engines
Liked 239 Times in 114 Posts
If you Google GM lifter/valvetrain noise there are a lot of "fixes" . Most involve pouring some type of product into the oil to clean crud out of the lifters . Seafoam comes to mind , or Marvel Mystery Oil . Worth a try before getting inside the engine .
After not hearing it all weekend it came back briefly this morning when was still cold. No noise when I stopped for gas. BTW turned 249K this morning. So first thing this morning I will figure out which rocker/lifter/valve is making the noise, if it does it again, and then try some of the "fixes"mentioned. Still going to buy valve cover gaskets in case we have to pull a cover.
I have seen many worn push rods and rocker arms the end of the push rod will look ovaled and shinier than the rest many cams and cam bearing but not for intermittent noise I work in a gm dealership
