Liked 1,471 Times in 308 Posts
I just looked at my metric 200 case, getting ready for spring, and it has
the dreaded bell housing crack. I have another case, but it has the solenoid plug for a lockup which mine does not have. Can I swap the internals, or do I need the non-lockup case? Thanks, J.R. |
Liked 312 Times in 175 Posts
Have a competent shop Tig weld it for you.
That's my 3rd or 4th option, trying to find out about the cases. J.R.
Liked 53 Times in 17 Posts
Whose trans is it?
Liked 239 Times in 114 Posts
You should probably replace the case with a pre-1981 case , so that your spacer plate and VB will be compatible . Hopefully you are not running a solid transmission mount , which would put extra stress on the case . Also did you cut the "ears" off the bellhousing for header clearance ? Sometimes that creates a stress riser .
Ron, it was built by Dynamic. No, don't run a solid mount, but replaced
what looked like a tired beat up one with a new hard rubber one last year. No, didn't cut the ears off. J.R. |
We broke two cases until we went with McClay with the strut on it for the Corvette. No problems since.
Liked 8,114 Times in 1,531 Posts
The brace on the pass side is a must have item....If you really want to sleep at night call Leo G. For the replacement bell housing. Money well spent and far superior to the factory metric case.....
Liked 66 Times in 37 Posts
J&W Ultra bell
72 cutlass |
#10 | |
Liked 62 Times in 29 Posts
