Old 03-26-2017, 10:49 PM   #1
Stirk18
Default IHRA Super Stock Production class
Looking at all the possible combos for a 1969 Convertible Camaro came across the IHRA Super Stock Production class.
Got a couple of questions, hoping someone can relay some answers or help guide me in figuring out a few things.
1) It says Factory produced heads. Can we use IHRA approved replacement heads like some other IHRA/NHRA BBC combos list, or must they be a Factory original GM produced heads and the replacement heads are not permitted??
2)Where do I find the IHRA approved list of Carbs?? It states you can use any IHRA approved carb but I cant find a guide for anything on the IHRA site? Wasnt sure what was applicable from the NHRA lists? Just trying to figure out what the biggest carb one could use would be that is still legal?
3) Intake Manifold, my generic understanding is you can use any manifold aslong as it fits on the heads and fits under the hoodscope with the carb on?
Any help here would be appreciated!
Thanks,
Andrew
Stirk18 is offline   Reply With Quote
Old 03-26-2017, 10:55 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: IHRA Super Stock Production class
I have emailed questions to Mike Baker , and gotten answers back in less than an hour .
ss3011 is online now   Reply With Quote
Old 03-27-2017, 05:59 PM   #3
randy wilson
Liked 22 Times in 22 Posts
Thanks,
Andrew
You can use any factory part number head. Such as the Dart Buick, GM 18 and 15 degree aluminum heads for small block. Also GM SB2. Big block is the same way.
don,t have one
Old 03-27-2017, 06:31 PM   #4
Steve Stasko
Liked 274 Times in 143 Posts
1) Yes, you can use approved replacement heads.
2) As far as the largest carburetor, the Dominator is legal.
3) Correct on the intake. You're allowed a snorkel scoop on a fiberglass hood as well. I seem to recall there may be a height restriction though?
I explored this option with my Hemi Coronet when I first started putting it together. The indexes were favorable, but the downfall is the NHRA crossover. You have to run SS/Modified in NHRA, and unless you are stupid quick on the IHRA index, you will barely make the NHRA Modified index. Essentially the potential for crossover is limited.
I would explore the option of building the long block to conventional SS rules, and just swapping the intake or lid if you wanted to run it in Production.
As stated before, Mike Baker is very easy to work with, and quick to respond if you cannot get in contact with him.
Old 03-28-2017, 12:33 AM   #5
Stirk18
Thanks for the info. Reason we are looking at Production is that we have alot of older bracket racing blocks and heads that currently are close to making the power needed to break index with this combo... and truthfully we just need to get our feet wet class racing, and with no NHRA races near by and atleast some IHRA races as well as our local S/SS series, the production class gets us into Super Stock mode easier and cheaper then trying to build a regular SS combo....
Thanks,
Andrew
Old 03-28-2017, 12:42 PM   #6
340Cuda
Liked 805 Times in 341 Posts
Quite a few years ago Mike told me when asked for the approved list of carbs for Super Stock Production:
"The production carb is any holley or holley types aftermarket unit"
I assume that still stands.
Bill
Old 03-28-2017, 06:32 PM   #7
Larry L.
Liked 4 Times in 1 Post
Stirk 18 like Randy said the heads for your Camaro to run in super stock production must have a GM part number.
Larry L. is offline   Reply With Quote
Old 03-29-2017, 01:09 AM   #8
Stirk18
Yup, we are good there, all three sets of heads have GM part numbers, the two aluminum ones and the Steels 990 castings.
Thanks for the help
Andrew
Old 04-01-2017, 06:44 PM   #9
jaf2021
Liked 5 Times in 5 Posts
any restrictions on the heads such as valve size,cc's or anything else or just as long as its got a gm part number you are good to go? also what is the difference between the pe-1/pea-1/pe-2 and pea-2 classes?
jaf2021 is offline   Reply With Quote
Old 04-01-2017, 08:38 PM   #10
joe collins
Liked 22 Times in 16 Posts
one is for 4 speed transmission one is for automatic transmission
joe collins is offline   Reply With Quote
