Liked 54 Times in 24 Posts
I have a customers LS engine that I installed an energy recovery oil pump in. Last season with a standard volume Mellings pump and 5/20 or 0/20 oil @ 120f max coolant temperature, the car would leave the line at 90PSI and go through at 78 to 82.
With the new pump, first warm hit on the dyno, it shot up to 150 psi and stayed all the way through ( may have been higher as the transducer on the dyno is rated at 150# max). It had the smallest spring and the the poppet ball moved freely. I talked to Vern S. about the pressure and he was very helpful and talked through things to great extent. In the end he theorized that the oiling system in the engine was very efficient and recommended shortening the spring and teeing the bypass hose to route some of the bypass oil to the screen / box area of the pick up and the other back to the tube as originally designed. He also stated if pressure is still to high to shorten the spring at .030' increments until I get what I want. Now with that done with warm engine , 0/20 oil, it idled at 40 to 50# and shot up to and leveled at 100 / 105# as soon as the throttle was snapped. Still to high. I have made adjustment to shorten the spring another .030". Customer will have it running this week and hopes to test. Has anybody run into a similar experience? This is the first time I have utilized this type of pump and although I understand the theory of the energy recovery pressurizing the inlet side of the pump, I am still really surprised that a thinner pump develops higher pressure ( w/ short spring ) and ramps up so quickly compared to the Mellings on the same engine.
Todd Gross 3323 FS/E,F |
#2 | |
If your application is for a Stock or Super Stock engine, this pump is an overkill. This Energy Recovery version of his pump is more effective when used with a Petersen external oil pressure regulator and to adjust its operation, in lieu of an oil pressure gauge, you use an inline flowmeter and adjust the oil pump for a specific oil volume flow. I know of a racers that have been using the Energy Recovery oil pump with the external regulator successfully on high RPM engines making 1000+ HP. If your application is a Stock Eliminator, his Pro Standard version of the pump would suffice; if a Super Stock, you can use either the Pro Standard or the Pro Maxx version of the pump. |
#3 | |
This pump was special ordered and speced out for a Factory Stock application when ordered. With that said, using an external regulator is not accepted as I'm sure you know. There are others in F/S using the energy recovery pumps that is why the owner requested to switch over.
#4 | |
Ask Vern how low you can go on oil pressure and still keep at minimum 8.0+ GPM at high RPM's without cavitating. Also ask Vern if he has a weaker relief spring that would do the job in lieu of cutting more of the spring. Eventually with use and heat cycles, the spring will change its tension. |
Liked 269 Times in 99 Posts
Are you running a paper oil filter or screen?
Screen filter. I do not know how many micron off the top of my head.
#8 | |
I advised him to remove the cartridge and start it to see if there was a difference. He just reported back, no change. I'll call Vern again tomorrow.
#9 | |
If the oil filter is a System 1, remove it and put a standard Wix or Hastings oil filter and test the pressure again. The System 1 billet oil filter has a known history of giving problems to many racers and engine builders with either extreme high pressure or oil pressure fluctuations. The only billet oil filter I recommend is the Pure Power Billet oil filter. It has a bypass and it is well engineered for the specific engine, including a dedicated oil filter for LS engines. |
It is a Pure Power filter. I talked to Vern today and he gave the filter his seal of approval.
Also on a side note, he went on to say there are a bunch of bad paper filters out there now. He would not state brands, but there some with debris that coming out of the paper. Blow in some 15-20 psi air and see if a cloud comes up. Otherwise he said to keep the purple spring and back it off until the hi rpm pressure is down to 85 to 95#
