Old 04-22-2017, 12:42 AM   #1
Everett Vassar
Liked 2 Times in 2 Posts
Default Min weight help
84 Cutlass Brougham 305 150/232....using Dwights tool and my own math I'm having trouble determing min
weight in L/SA..is the factor 13.4 or 13.5 ? Min weight 3280 or 3288 or 3302...thanks?
Everett Vassar is offline   Reply With Quote
Old 04-22-2017, 02:42 AM   #2
Tom Moock
Liked 10 Times in 6 Posts
Default Re: Min weight help
13.5 x 232 =3132 + 170 = 3302 round down to 3300.
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 04-22-2017, 03:22 AM   #3
Everett Vassar
On Dwights tool,above the classes the car can run in,it says power/weight factor: 13.44 what is this used for?
Old 04-22-2017, 08:10 AM   #4
Liked 10,789 Times in 2,242 Posts
Shipping weight / NHRA hp = natural class
Old 04-22-2017, 08:37 AM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
That is the natural classification power to weight factor you get when you divide the shipping weight by the NHRA power factor. That's what Larry was telling you. (Shipping weight is 3117, power factor is 232.) That number fits between 13.00 and 13.49 on NHRA's classification scale so it is a "natural" K car. Rules state that you can remove weight to the lightest possible weight for that class, so the minimum racing weight for K will be 13.00 x 232 = 3016 lbs + 170 driver allowance = 3186 lbs.
Rules also state that you can move one class down or one class up, so the other calculations from the tool show the minimum racing weights for J and L, calculated be multiplying the minimum power to weight factors for each of those classes by the power factor for the engine.
The 13.44 factor determines the classification to start the calculations. It is the numbers found on the spreadsheets that NHRA uses for that car-engine combination and is the starting point their people use to do their calculations. My tools does all that for you.
Old 04-22-2017, 09:19 AM   #6
Billy Nees
Liked 7,790 Times in 1,744 Posts
And just another "Thank You" for doing all of the work in getting this site up! It's much (much) easier than the NHRA site. All of the work is done.
Billy Nees 1188 STK, SS
Old 04-22-2017, 12:19 PM   #7
Everett Vassar
Thanks Dwight and everyone else for clarifying. We are over the min now just want to make sure I don't do something stupid
Old 04-22-2017, 05:20 PM   #8
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
and I would suggest rounding up to 3305 + 10 and not rounding down which would make you light at the scales
Bob Mulry 7516 STK
A & M Motorsports
Old 04-22-2017, 06:27 PM   #9
Not So Fast
Liked 11 Times in 4 Posts
Questions regarding running at minimum weight (13.00) with a 13.44 car and about moving a class up or down. Specifically, if a car comes in above minimum weight (ie. 13.44) for a class (K), is it allowed to run on the minimum (13.00) K weight or does it have to run at the actual weight (13.44) in K?
Similar questions if the Oldsmobile were to move to J, would it be allowed to run at 12.50 (minimum J weight) even though the car comes in at 13.44?
Can someone provide the page in the rulebook or a copy of the actual rules being referenced?
Thank you in advance for clarification and to Dwight for creating a database.
Not So Fast is offline   Reply With Quote
Old 04-22-2017, 07:10 PM   #10
Bob Mulry
Bob Mulry's Avatar
2017 NHRA Rule Book....Section 10A Page 8
WEIGHT
All cars will be permitted to run on the class minimum weight, but
may be no heavier than the minimum for the next heavier class.
Car can move up (lighter) one class or down (heavier) one class. If
weight is added, must be properly attached; see BALLAST. Class
Bob Mulry 7516 STK
A & M Motorsports
