Old 04-24-2017, 03:22 PM   #121
Paradigm Shift
Liked 80 Times in 29 Posts
Default Re: Who's the Baddest B/SA now?
The lighter weight guy with almost as much power as the heavier vehicle?
Maybe even a Ford?
Paradigm Shift is offline   Reply With Quote
Old 04-24-2017, 05:00 PM   #122
Liked 10,969 Times in 2,261 Posts
^^^^^^^ Are you speaking of "creative writers cramp" Mr Bill (Pop up piston) Hawk?
Old 04-24-2017, 05:19 PM   #123
Paradigm Shift
Now that you've mentioned him, he can be a formidable challenger.
Never mind about the combination and the attendant components.
Still other FE competitors remain and should reasonably be included within this conversation.
Old 04-25-2017, 10:49 AM   #124
Kenny Boy
Banned
Originally Posted by Chad Rhodes View Post
Hey Kenny Boy do you like apples??
How you like them apples?
37 HP
Same motor, 37 HP (310 lbs) penalty
Only out run by 0.03?
Here is some apples to think about...
Same Motor, Same Specs, Lets switch them.
How much "Bad'r" would the Corvette be then?
I think at least 3 tenths, or it blows the tires off
How fast you think that camaro would go at corvette weight?
Apples
Kenny Boy is offline   Reply With Quote
Old 04-25-2017, 12:44 PM   #125
junior barns
Liked 20 Times in 14 Posts
Originally Posted by Kenny Boy View Post
37 HP
Apples
Have to agree!! BUT lets face it, J Allen was fender driving from the 330! No sense in getting hp if you don't have to. I think all models with same engine combo should be rated the same unless these cars can top 140mph! You wont see areo pkg much difference until reach this speed! ( In my opinion)
junior barns is offline   Reply With Quote
Old 04-25-2017, 01:41 PM   #126
Rusty2211
I frankly think it's a shame you have all that motor in the wrong car. I would beg, borrow, start a gofund me page or whatever it takes to get a vette to slide that motor into. Then I'd put it in "blackbird" mode and let her eat until you get the horsepower equalized. After that, slip the engine back into the bird and this can be settled once and for all. The other option is to drive around for a couple of years in super-slow mode and write a letter. Never heard of anyone doing that though.
Rusty2211 is offline   Reply With Quote
Old 04-25-2017, 04:27 PM   #127
Paradigm Shift
Wow! Is that accurate?
That's a dramatic difference in overall weight. Square these up and I'm confident the fender advantage your referenced goes away and then some.
That Camaro certainly makes significant power. Who prepared the engine?
Drag coefficients begin to play a role well before 140.
Old 04-25-2017, 06:17 PM   #128
Chad Rhodes
37 HP
Apples
If that was Allen's good engine, I might agree. However, it's a new car that still has some in it, and if my memory is correct it's got an engine he took on trade in it. I mean I guess he could drag the red car back out and set the record so low that people start selling their cars, but what's the fun in that.
Chad Rhodes 2113 I/SA
Old 04-25-2017, 07:25 PM   #129
SSDiv6
The drag created by any car body in motion, is proportional to the square of velocity, so it is important at any speed. The force will increase as the speed increases.
Drag starts to have a noticeable effect at 10 MPH and downforce, depending on the frontal shape of the car, as early as 40 MPH.
This is not taking into consideration the rake of the body as it accelerates down the track.
Like the adage says, looks can be deceiving. Although a car may look or appear to be fast just by its looks, it does not mean it is aerodynamically efficient.
The 1998 thru 2002 Camaro are one of the most aerodynamic cars ever built. Below are the body specs:
Wheelbase
101.1
Track Width (Front)
60.7
Track Width (Rear)
60.6
Length
193.5
Width
74.1
Height
51.2
Ground clearance
4.5
Cd
.34
Below are the body specs for the Corvette:
Wheelbase
104.6
Track Width (Front)
61.9
Track Width (Rear)
62
Length
179.8
Width
73.6
Height
47.7
Ground clearance
4.0
Cd
.32
The Camaro has a shorter wheelbase and narrower body than the Corvette.
The Corvette has a lower roof height and shorter length than the Camaro.
The difference in both cars drag coefficient is only .02 which in the case of a drag car, is technically irrelevant.
So in a nutshell, the Corvette does not have an advantage over the Camaro as regards to body size or aerodynamics.
As a matter of fact, I believe that more detailed analysis will show the longer body and rear shape of the Camaro is an advantage at higher speeds and weight transfer when compared to the blunt, short rear of the Corvette.
Old 04-25-2017, 08:39 PM   #130
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
I'm surprised talk on this is continuing. J Allen can bomb the B/SA index anytime he wants. But that would be stupid. I've seen a video of the red vette testing at B weight and all I will say is you boys better find some more............
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
