Old 05-04-2017, 06:14 PM   #1
rseibenick
Liked 20 Times in 7 Posts
Default Onan voltage regulater
Anyone know where I can got a Onan generator voltage regulator Part # 305-0826 at a good price. Thanks.
rseibenick is offline   Reply With Quote
Old 05-04-2017, 06:43 PM   #2
voltdr
Liked 100 Times in 51 Posts
Default Re: Onan voltage regulater
Try flight systems
http://www.flightsystems.com/p-ONAN-...FUMcaQod0RYDpQ
voltdr is offline   Reply With Quote
Old 05-04-2017, 06:44 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,948 Times in 589 Posts
There is lots of Onan parts available on e bay. Just doe a search for the part number
Mike Pearson 2485 SS
Old 05-04-2017, 07:11 PM   #4
rseibenick
Thanks for the information. Will check them out.
Old 05-04-2017, 08:20 PM   #5
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
"Parts for Techs" is a website that sells what you are looking for. Just Google search that and it should get you there. Flight Systems is also a good source. ASAP is Parts for Techs.....same place. I buy parts from both sometimes. That regulator is one of the more expensive units and is externally mounted. Probably a Marquis.....
Rich Biebel
S/C 1479
Stock 147R
Old 05-04-2017, 08:43 PM   #6
Hacksaw
Liked 312 Times in 175 Posts
I also have used ASAP / Parts for Techs. Good service and reasonably priced.
Old 05-04-2017, 08:57 PM   #7
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Wide range of prices, but there is one on eBay for $222.00 . There is a good set of instructions that I saw when I Googled that part number , to test the old one to make sure its bad . Doesn't look like a very robust connector , might try cleaning it good and retrying it . Good luck !
Old 05-05-2017, 10:20 AM   #8
rseibenick
Yes its a Marquis 111. will try cleaning the contacts first and see.
Old 05-05-2017, 12:00 PM   #9
Rich Biebel
Won't help. It's never been an issue. First thing to check on those is always brushes, and slip rings. The brushes ride on those slip rings. Copper surfaces on the rotor. A normal ohm reading right at the back of the brushes with at least one wire pulled off........about 20-30 ohms. If brushes and slips are good you can pull wires off brushes, tape them up and connect a 12volt battery or better yet a 24 volt supply right on there and run it. Output should be produced although it will be low. That test will be proving the rotor and stator are good. 30 to 60 volts D.C. is the normal range there. Marquis' are complex units with electronic governors. Harder to diagnose than manual governors. Pretty easy for me though.
Rich Biebel
S/C 1479
Stock 147R
Old 05-05-2017, 02:25 PM   #10
rseibenick
Rich, had the unit checked out and they said it was a bad voltage regulator. Slip rings and brushes good. Will try to clean the connectors and try that if not will change out the regulator.
