#11 |
Liked 312 Times in 175 Posts
Robert: Did you figure it out?
#12 | |
Liked 20 Times in 12 Posts
#13 |
Liked 552 Times in 215 Posts
The secondary spring arrangement is not really very safe.
I once had that spring pop off and my throttle went wide open. Engine sucked it wide open...... The car was on the trailer inside my garage. I was messing with something, probably the carb. I revved it up a couple times and it went wide open..... I shut the air valve with my hands and a friend managed to kill the ignition switch.....He hit the switch so hard it broke off.....but did shut it down.... I never saw it happen before that on any Q-Jet.....street car or race car... The spring must not have been properly in place but it showed me what could happen..... Drill and pin the lever to the shaft..... Q-Jets are great when they work well.....but can really give you fits....
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 04-24-2017 at 12:40 PM. |
#14 |
Update. Removing the spring on the secondary shaft and pinning it was the key. I made a pass last weekend and drove past the finish line and pedaled it a couple times and it worked. I dial honest but now I know if I need to pedal it should respond ok. Thanks to all the suggestions it is appreciated. Now if I can just figure out how to lean up the mid range it would be good, any suggestions out there on that?
Robert |
#15 | |
Liked 1,955 Times in 590 Posts
Mike Pearson 2485 SS |
#16 | |
#17 |
Try a smaller main jet to lean it early in the run, although a 65 should be lean enough. Make sure the primary plunger cavity is plugged. Put a thinner metering rod in to richen it up at the top. What rods are you using now?
#18 |
Check the plugs on the bottom of the carb body with the base plate off to make sure the plugs are not seeping. That will richen up the idle and low end if they are leaking. put some JB weld on them just to make sure. Also check the float level and fuel pressure. 6.5 lbs should be more than sufficient. I also put a 90 degree spark plug boot on the vent tube facing forward. Do you have electrical tape around the secondary metering rods to control slosh that can splash up around the secondary rods? My cab has a small plate that fills the area around the secondary metering rods but you have to mill the bottom of the carb top for the plate to move freely. What rod size are you running in your carb?
#19 |
Liked 27 Times in 19 Posts
Are you allowed to use screw in air bleeds?
#20 |
Thanks guys for the suggestions. This is a 77-78 model carb that I use on my street car/footbrake car. I do not have primary rods in it. I have been playing around with it to make it better for what I am doing. I can put air bleeds in it if I wish. My main question is what part of the carb helps deterring the mid range fuel mixture? I am asking if the air bleeds in the main body would have the largest effect on tuning the fuel curve in mid range? In my case 28-4000. I did discover that I have to much total timing so that prob is contributing to the slight lean occurring up top. I am working on the dist to fix that. Thanks again.
