Liked 20 Times in 7 Posts
Anyone know where I can got a Onan generator voltage regulator Part # 305-0826 at a good price. Thanks.
Liked 100 Times in 51 Posts
![]() Last edited by voltdr; 05-04-2017 at 06:46 PM. Reason: better link |
Liked 1,983 Times in 597 Posts
There is lots of Onan parts available on e bay. Just doe a search for the part number
Mike Pearson 2485 SS |
Thanks for the information. Will check them out.
Liked 557 Times in 217 Posts
"Parts for Techs" is a website that sells what you are looking for. Just Google search that and it should get you there. Flight Systems is also a good source. ASAP is Parts for Techs.....same place. I buy parts from both sometimes. That regulator is one of the more expensive units and is externally mounted. Probably a Marquis.....
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 05-04-2017 at 08:22 PM. |
Liked 314 Times in 177 Posts
I also have used ASAP / Parts for Techs. Good service and reasonably priced.
Liked 239 Times in 114 Posts
Wide range of prices, but there is one on eBay for $222.00 . There is a good set of instructions that I saw when I Googled that part number , to test the old one to make sure its bad . Doesn't look like a very robust connector , might try cleaning it good and retrying it . Good luck !
Yes its a Marquis 111. will try cleaning the contacts first and see.
Won't help. It's never been an issue. First thing to check on those is always brushes, and slip rings. The brushes ride on those slip rings. Copper surfaces on the rotor. A normal ohm reading right at the back of the brushes with at least one wire pulled off........about 20-30 ohms. If brushes and slips are good you can pull wires off brushes, tape them up and connect a 12volt battery or better yet a 24 volt supply right on there and run it. Output should be produced although it will be low. That test will be proving the rotor and stator are good. 30 to 60 volts D.C. is the normal range there. Marquis' are complex units with electronic governors. Harder to diagnose than manual governors. Pretty easy for me though.
Rich, had the unit checked out and they said it was a bad voltage regulator. Slip rings and brushes good. Will try to clean the connectors and try that if not will change out the regulator.
