Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 05-05-2017, 03:00 PM   #11
Wayne Kerr
Liked 26 Times in 11 Posts
Unhappy Re: wrist pin clip issues
Ron,
You are going to have to trust me on this, and all the "experts" on here are going to piss and moan.
You need to have more pin end play. The reason the other engine opened up to .035" is because that's what it wanted. The pistons deflect from gas pressure and the pin bosses flex inward. We built a fixture and we put 1500 psi nitrogen on top of a room temperature piston just to prove this fact. Lost numerous cup engines and a few IRL engines as well, with too tight of wristpin end play.
Wristpin end play is like bearing clearance, too much and you know about it, too little and everybody knows about it.
See you at the races,
Wayne Kerr
Wayne Kerr is offline   Reply With Quote
Old 05-05-2017, 05:04 PM   #12
Jeff Stout
Liked 704 Times in 281 Posts
Default Re: wrist pin clip issues
Originally Posted by Wayne Kerr View Post
Ron,
Wayne Kerr
What would be the desired amount of end play on a medium performance engine 150 wall 153 gram, and 545 gram piston, 3.385 stroke? I have .027 right now
Old 05-08-2017, 08:48 AM   #13
Wayne Kerr
Good morning Jeff,
There are certainly many factors that are in play here. The first is piston design, the new "Box bridge design" pistons are reinforced in the pin boss area and can run less wristpin end clearance. .025" would be adequate for that type of piston while the old full round pistons like a Venolia, I would like to see .040"+
Bore size will play a role as well, bigger bore, more piston deflection.
Wayne Kerr
Old 06-09-2017, 08:54 PM   #14
Jim Hanig
Liked 99 Times in 49 Posts
Good morning Jeff,
Wayne Kerr
Wayne what is èasy best way to check this..? Thanks
Old 06-12-2017, 12:04 PM   #15
Charlie Yannetti
Liked 192 Times in 83 Posts
Simple question.. how much vacuum are you pulling??.. too much vacuum will affect oiling to the wrist pins, and possible damage... just an idea..
Charlie Yannetti is offline   Reply With Quote
Old 06-23-2017, 11:52 AM   #16
Wayne Kerr
Just use a regular one inch travel dial indicator, with an extension. Welding rod for the extension will suffice.
Wayne Kerr
Old 09-08-2017, 10:48 AM   #17
Adger Smith
Liked 880 Times in 311 Posts
Wayne,
I'm not squirming or pissing and moaning. I agree with you on clearance, but too much makes the pin act like a battering ram on the clips. most applications I deal with .002 to .006 is plenty. But first Get the alky tune up correct where it won't flood when the driver is pedaling it and the pistons and pins won't deflect so much they need more clearance. I do agree pins need end play, but most pistons grow outward at the pin boss when the engine heats up making more pin end play. Flooding it with the alky is probably keeping piston temp down = no piston growth & more deflection of the pin and piston. I have seen the very same thing in Dirt engines with 4" bores. It bothers me to see a driver that has abusive habits. Some times those DT cars have drivers that are real harsh with the loud pedal, too.
There could be multiple issues with this one. It could even be a set of pins that are not up to handling the load the alky puts on them. Pin deflection can be a real serious issue on high cylinder pressure applications. Good luck fixing it.
Adger Smith (Former SS)
