Old 05-05-2017, 03:09 PM   #11
MIRADA
MIRADA's Avatar
Default Re: Onan voltage regulater
The regulator is available thru your nearest cummins dealer
Not sure how much they are in the states , but they are $875 Canadian
And are a week or so away if that helps , I work for a Peterbilt dealer
And we can get them from Memphis warehouse...
Alan Harper
SS/KA 1072
Dodge Mirada
MIRADA is offline   Reply With Quote
Old 05-05-2017, 04:08 PM   #12
voltdr
Liked 100 Times in 51 Posts
The one from flight systems is $245.00
voltdr is offline   Reply With Quote
Old 05-05-2017, 04:55 PM   #13
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
The Onan part is $413 list price...
You would be very lucky to find anyone selling it for much under list....
If the unit was diagnosed as having a bad VR your options are either an Onan or one from Flight or ASAP and ASAP sells both for some machines.....
I am and our facility is an ONAN authorized repair facility.....20+ years....
I have and use a G-Man generator tester as well as a variable voltage power supply to diagnose these machines.
The G-Man is a breakout box and is good but it cannot substitute for a "known good" Voltage regulator......
I always confirm all other components are ok before plugging in a new VR....
Rich Biebel
S/C 1479
Stock 147R
Old 05-05-2017, 06:00 PM   #14
rseibenick
Liked 20 Times in 7 Posts
Rich, the tech. plugged in another regulator and it worked., had ac power .It was not the exact right one , but he said it should tell me if mine was bad. He said I should get the exact one Onan had for that generator.
rseibenick is offline   Reply With Quote
