Old 05-06-2017, 09:12 PM   #21
Kdw1403
Liked 68 Times in 22 Posts
Default Re: Question about fuel injection from a newbie
Engine was not running.
Kdw1403 is offline   Reply With Quote
Old 05-06-2017, 09:15 PM   #22
Buick6
Liked 16 Times in 7 Posts
I don't know how your pump is wired. You may want to try checking with the engine running with alternator output.
Buick6 is offline   Reply With Quote
Old 05-06-2017, 11:01 PM   #23
Kdw1403
I unhooked wires from fuel pump. Hot wire reads 12.58 volts with battery reading 12.6. Engine not running. Changed ground of fuel pump from frame to battery. Still reads about 8.5 volts when I touch leads to fuel pump while it's running. If I unhook ground wire and check the hot wire while it is connected to the pump (pump is not running) the wire reads 12.58.I am a terrible electrical person so please forgive me if I am ignorant sounding.
Old 05-06-2017, 11:55 PM   #24
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Originally Posted by magnumv8 View Post
Actually the reason they went to 60 lbs.of fuel pressure was that the bean counters got involved in the cost reduction of the package...the horsepower was pretty much already there and it was a lot cheaper to raise the fuel pressure than it was to purchase Millions of bigger injectors to give you the same fuel volume....while a finer fuel mist IS easier to ignite the volume of fuel you are trying to burn is the same because you haven't changed the amount of air ingested and you are working with a specific A/F ratio...any horsepower increase is minimal but when working on 1 engine instead of Millions the cost is easily justified when any increase in power is good.....
D L Rambo....Stk 1300
The LS1 Injector is a big improvement over the LT1 Injector.
I like the ability to change Fuel Pressure and Tune for Power.
Could not do that as well with the LT1 Injector.
Plus the LS1 is less prone to clogging and has a finer mist!
Believe the Ford 24# Injector works well too.
D
Old 05-07-2017, 08:23 AM   #25
Ed Wright
Ed Wright's Avatar
No reason at all you could not alter tuning by altering the fuel pressure with the factory LT1 injectors. I know NHRA Stock Eliminator racers that do it all the time. Turn the fuel pressure up on an LT1 injector, they have a finer mist as well. That is the point. Higher fuel pressure atomizes the fuel better. That is the reason for higher fuel pressures being used. Better emissions is the main reason. Very small power increase are simply a bonus.
I use injectors from FAST in mine.
Ed Wright 4156 SS/JA
Old 05-07-2017, 08:32 AM   #26
Buick6
Check the installation instructions for the A1000 to see if they can help.
https://www.aeromotiveinc.com/tech-h...-instructions/
Old 05-07-2017, 06:15 PM   #27
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Maybe I missed it somewhere here. What size wires to the fuel pump? Have you tried a new wire from the battery to the pump and checked voltage? You could take the battery and make up leads that would go directly to the pump and check it, that eliminates all other wiring. Then start eliminating wires from there.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 05-08-2017, 01:28 PM   #28
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
I am irritated! I believe what your are saying. It makes sense. But Holley and Fast and some others say it's best to run fuel pressure at what the injector is rated at. On most injectors they are rated at 44.5 so I've got mine right at 45. I will raise the pressure next weekend.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 05-08-2017, 01:41 PM   #29
Ed Wright
Ed Wright's Avatar
Injectors are flow rated at 43.5 psi, I believe.
Not sure why they would tell you that. I'm not the only one that found power there.
Listen to who you want to.
Or, test things for yourself.
Old 05-08-2017, 01:45 PM   #30
Darrel Goheen
Yip your right. 43.5 not 44.5. Like I said I believe you and it makes sense. I'll be raising my pressure to 60 this coming weekend. Will you be at Topeka Nationals? Thanks.
