Old 05-09-2017, 03:10 PM   #11
Comp 798
Comp 798's Avatar
Default Re: Question: K&N Air Filter for LT1
Mark, is it a K&N or? Do you have a part #? Thanks.
Sam Tufano
Comp 798 is offline   Reply With Quote
Old 05-09-2017, 03:14 PM   #12
Mark Faul
Liked 43 Times in 9 Posts
Sam, yes it's a K&N. I'll take a look later to see if I can find a number.
Mark Faul is offline   Reply With Quote
Old 05-09-2017, 03:30 PM   #13
Ed Wright
Ed Wright's Avatar
Originally Posted by Mark Faul View Post
I run mine all the time on my Super Stocker. Had to put a little dent in it and tweak it to fit around the front drive distributor. Haven't noticed a difference with it vs without. But I don't make much HP.
If I tried Ed's towel trick, I'm sure I'd forget and leave it on. Not quite as old, but forgetful! LOL
Sounds like I need to take another look. Just pushed a dent in the filter? Hogan intake?
Ed Wright 4156 SS/JA
Old 05-09-2017, 08:39 PM   #14
Mark Faul
I couldn't find a part number anywhere. Hopefully these help? A little crude, but it worked.
ID:	39510   Click image for larger version
Old 05-09-2017, 08:42 PM   #15
Ed Wright
Ed Wright's Avatar
Thanks Mark!
Old 05-10-2017, 09:53 PM   #16
SSDiv6
Check out K&N Air Filter RC-5004; I believe it's shorter.
Old 05-10-2017, 10:15 PM   #17
Comp 798
Comp 798's Avatar
Thanks..... I found RU-5004 which is the plain version. They are dimensionally the same and both 3.5" long. Just right for keeping the debris out before and after a run.
Sam Tufano
Old 05-14-2017, 08:45 AM   #18
Tony Goodman
Liked 18 Times in 4 Posts
K&N has a custom build dept. I had one built for my car. It's basically a #5020 that is as long as I could get before it hit my radiator. Its about 6.5" long verses the 5020's 3". I also had only a single layer of filtration material used instead of multiple layers.
Tony Goodman is offline   Reply With Quote
