Liked 54 Times in 24 Posts
Has anyone experience with wiring the late model Challenger door glass with the smart controllers. The 09-11 Drag Paks have specific controllers that wired different from stock to control the electric windows. Those controllers are no longer available, as I've been told. I tried wiring the OEM controllers the same as the DP, but do not operate.
I have been sifting through schematics trying to piece it all together, but thought I'd ask if anyone has experience in this that may give me a short cut. Thanks
Todd Gross 3323 FS/E,F |
Liked 8 Times in 5 Posts
I have new 08/09 Drag Pak window controllers. PM me John
John Donato Stk / SS 3435 |
They are in and they work as intended. Thanks John!
Liked 883 Times in 237 Posts
One thing I have found on the DP window controls is they do not like 16v systems.
They will usually work when the car is not running , but when the car is running with a functioning alternator , voltage approaches 18-18.5 volts and the control module shuts down . I fixed the problem on one of the DP's I work on by using a Runtz dropping resister that is made for dropping 12volts down to operate 6 volt gauges on cars that were converted to 12 v.
#5 | |
Scott justo. 2009018 lc22r |
Scott, you can try this reducer ,it's made to reduce from 18 volts to 12 for electric golf cart radios. I've had good results with it.
Jeg's part number is 811-conv-00
Liked 341 Times in 67 Posts
CAN buss controllers do not like anything more that 18 volts. I have seen systems fail completely at just over 18 volts.
Thank you Tom I will try that.car is at the tuners shop right now and the window issue is the last thing to do before its first trip down the track.
Liked 693 Times in 205 Posts
I have a 2016 Challenger and need help trying to get the power windows to work. Anyone know how to wire this and make this work? I am not using the factory ECM, but have the factory wiring in the doors. The Drag Pak controllers are no longer available. Thanks, Dyno 763-227-336six
Liked 370 Times in 101 Posts
Dyno, just run the AC.
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
