#61 |
Liked 295 Times in 111 Posts
Let's mix this up a little. If there is no dial-in on your car the class index is your dial. So with an incorrect dial above the index, correct one should also be inserted. In other words you cannot dial above your class index, otherwise we ARE just Bracket Racing (Dial your own).
#62 |
Liked 10,779 Times in 2,240 Posts
What about this: Heads up run with two different indexes on score boards, one correct and one over class index. Would it be the responsibility of the racer in the lane with the correct index to point out that the racer in other lane had the wrong (slower) index and had a distinct advantage? I don't know about other racers but in a heads up I have zero dial on the car, and doing everything to make sure I do everything correctly. I don't ever remember checking the dial in a heads up race. So who wins in a heads up race with this kind of mistake by race personal?
When is a racer staged? In my mind it is when the pre stage and the stage lights on his side of the tree are on. So...... racer A has both bulbs on and race B has one bulb on and then notices incorrect dial in his lane. Racer B backs out to notify official that dial is wrong, while all this communication is trying to take place with the official racer B get timed out and his side of tree goes red do to auto start. Does first or worst apply to racer B, both are wrong and correctable. and so it goes |
#63 |
So I guess I'm guilty of 'assuming' the sanctioning body should be in charge (electronically or human) of "running the show". OK so it's up to the racer to keep it straight and hope they're not, ahem, Ignored!
#64 |
If Redman (who actually knows sportsman racing) would have been the starter this would have never happened. Yes, it is up to the racer to make sure the dial is correct (all drivers are in "their zone" on the starting line), but does that mean he should be the only one paying attention. Where does our $360.00 go?
Chuck Beach 3340 STK Last edited by Chuck Beach; 05-10-2017 at 01:24 PM. |
#65 |
Liked 2,965 Times in 713 Posts
I have an interesting point on this. Shouldn't all this verification of dial in happen before you begin your burnout?? Once you accept the dial it is gospel. True the dial can't be more than the index, that is a given.
Once you light the top bulb I don't believe you can back out unless you are told to do so by the starter. I believe this is in the rule book. I could be wrong, I am only human and make mistakes sometimes.
Ron McDowell - Did Race Every day is a Gift - Enjoy with family and friends. Last edited by Carguy49; 05-10-2017 at 01:30 PM. |
#66 | |
Liked 5,129 Times in 1,956 Posts
Let's throw this out there then. Car A redlights Car B unloads an engine , last round of the day. Big clean up, start to finish. No weigh that round. Car B fixes engine overnight, and comes back next morning, right or wrong? Isn't that a worse infraction?
#67 | |
Liked 320 Times in 102 Posts
Wrong If the car was light or bad fuel, the moment the car staged he was a DQ...... The car that went red happened after the tree started down... First or worst...
#68 |
Liked 795 Times in 210 Posts
With well over 11,000 Views on this subject, i hope somebody in Glendora is reading this & all we could hope for is something like this to NEVER happen again.
In response to Chuck Beach: Where does our $360. GO ???? very good question. I still like a hand held iPad & you punch in your Car # and Dial before you enter the water box. But i'm sure NHRA would need different software or something to do that. But it would be worth it for 5 or 10 more dollars per racer IF it was an expensive fix. Just my .03 cents.
"Pistol" Pete Dutko |
#69 | |
Liked 68 Times in 41 Posts
x2
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
#70 | |
Liked 13 Times in 4 Posts
Joe Schaechter 3168 STK |
