View Poll Results: Fuel injection? Do you run in open loop or closed loop
Open Loop 80 65.04%
Closed Loop 43 34.96%
Voters: 123. You may not vote on this poll
Old 05-08-2017, 02:03 PM   #111
pbp1
Liked 27 Times in 6 Posts
Default Re: Fuel injection? Open or Closed loop?
Ed, What style of manifold do you run and where exactly is the Air Temp Sensor loacated?
David Page
Fuel Air Spark Technology (FAST)
pbp1 is offline   Reply With Quote
Old 05-08-2017, 03:04 PM   #112
Ed Wright
Ed Wright's Avatar
Hogan sheet metal, the sensor is in one of the bungs, above the distributor, on the back end of the plenum.
Ed Wright 4156 SS/JA
Old 05-10-2017, 10:24 AM   #113
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Originally Posted by cmracing View Post
I get about 200 or so passes on an NTK sensor using unleaded race fuel, sometimes more. This is with the Holley system. The Bosch sensor is about half that. If you limit your correction to +-5% or less, then if a sensor does go south, it won't kill the tune that bad. But, you do have to look at your datalogs and keep an eye on things....... I run Closed Loop in both of my cars, but also limit what I allow it to do.
I'm curious.....how often do you look at your data logs once you have it tuned? I'm still new so looking at most of the data logs but now they all are looking the same. Thanks.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 05-10-2017, 07:05 PM   #114
SS3718
Liked 27 Times in 14 Posts
Darrel,
I log every run and generally look at the graph after every run. I run a FAST system in open loop and like being able to review the data after each run!
Nick
SS3718 is offline   Reply With Quote
Old 05-10-2017, 07:27 PM   #115
Darrel Goheen
Originally Posted by SS3718 View Post
Darrel,
Nick
That's what I've been doing except when I'm lucky enough not to have time between runs to look at them
Old 05-10-2017, 08:19 PM   #116
Ed Wright
Ed Wright's Avatar
Darell, are you running it in speed Density, or Alpha N?
Old 05-11-2017, 01:36 AM   #117
Darrel Goheen
Density
Old 05-11-2017, 08:35 AM   #118
Ed Wright
Ed Wright's Avatar
Originally Posted by Darrel Goheen View Post
Density
Me too. Once I have run it, and got my A/F right on the row for that Baro, next time I run there (Great Bend, KS, Noble, don't use the same row in my VE table as Ennis, Houston, etc. Don't have to touch it. I have just about quit logging every run. Never have to touch it anymore.
In low gear, Closed Loop doesn't make corrections fast enough. If off at (for instance)7000, the ordectuon would end up at 7500, when it's referencing the 7500 cel, which needed no correction. I ended up trying to set the delay so corrections would not start until 2nd gear. I got it so Closed Loop was not making corrections in the upper gears anyway. I just put it back into Open Loop. With the IAT sensor, it's always dead nuts. The car repeats really well. Wish the driver did.
Old 05-11-2017, 09:53 AM   #119
Darrel Goheen
I'm getting very little correction at WOT. I've tried shutting off closed loop but it barely runs in the pits then so I have to turn it back on. I just need to get that area tuned in OL. So if you go to say Denver would you turn CL back on for a couple passes or just select the whole table and take a percentage of fuel out? Do you save a tune for every track? In CL I think my launch AFR is way messed up because of 2 step. As soon as I launch it adds quite a bit of fuel. Here's my thought at this point and please correct me if I'm wrong. Footbrake a couple passes to get launch area AFR close, turn off CL and get pit area tuned and then slowly adjust AFR according to data log? Racing gets critical now starting with Topeka Nationals.
Old 05-11-2017, 10:05 AM   #120
Darrel Goheen
More thoughts......
Since I most likely can't win a heads up based on performance I should quit worrying about getting every last hundredths of ET out of my cars. I should just get them tuned to where it's consistent and leave it alone. Agree?
