#71 |
Liked 584 Times in 94 Posts
At the Atlanta NMCA race, several weeks before the NHRA National Event, the dial in boxes at the starting line weren't working .... My question is, "Were they fixed and working at the National Event ?"
#72 |
Liked 70 Times in 31 Posts
Normally, unless you are at the front of your class you are burning out while a race is happening on track. I always verify the dial between burnout and pre-staging.
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
#73 |
Liked 2,951 Times in 709 Posts
Good point Darrel. I guess each track is set up different in respect to the burn out box, and how the racers approach it from the staging lanes. I am most familiar with Pacific Raceways in Kent, Wa. since that is closest to me.
Ron McDowell - Did Race Every day is a Gift - Enjoy with family and friends. |
#74 | |
Doesn't everyone wait for the clocks to re-set, before proceeding to pre-stage? I don't even look at dial-in boxes...just the scoreboards,..and the other car's dial in. I wouldn't stage if either one is wrong. Just about the time you pre-stage, they'll figure it out, and you'll be sitting there watching it all, and waiting. Of course, I'm just a keyboard jockey , according to a few here.
#75 |
Liked 460 Times in 91 Posts
William call me tomorrow
Bob Bender 144 O/SA 2010-2012 National Record Holder |
#76 |
Liked 46 Times in 20 Posts
If I remember correctly, it used to be that a driver could pre-stage, check the scoreboard and back out if there was an error with dial. That was changed quite a few years back that once you light the top bulb "you own it". I do my best to stop short of the beams, wait for the burnout smoke to clear (tailwind, right?) and the dials to pop up before I light the top (although I have to be honest there have been occasions when I didn't!). As much as I don't like the fact that if I correctly place my dial-in and someone in the tower makes a mistake with the input that I own it, however I do understand that it is my responsibility to check before pre-staging. What I would like clarity on is what happens if my dial gets entered over the index and I go on to "own it" and the other driver red lights, crosses the centerline, is light at the scales or does not pass fuel check. Who is the winner/wiener??? In my opinion, this is the only thing that needs clearing up. All else is clear, you pre-stage, you own it!
BTW-congrats to Cooter for his win in Atlanta. That's 2 consecutive years of azz kicking in ATL-he nearly doubled there last year. Know that the old man is proud! Deer stew and cold brew! |
#77 |
Liked 2 Times in 1 Post
I wonder why this hasn't been fixed yet. All it would take is one simple line of code:
if dialin > index then dialin = index I guess it would probably cost 3K+ to implement like the worst red light deal. Get it done Compulink! |
#78 |
Liked 704 Times in 281 Posts
I totally agree on having index being noticed on computer as being wrong if it is installed with a slower then class index. But some how the human error on correcting to proper dial in needs to be figured out.
It sounds like there is a warning that goes off in tower when something is wrong but human error is still in play to correct it. Drivers should never put their trust in someone else's hands when it comes to racing. I doubt anyone lets a stranger work on their car, check air pressure, add fuel. So why would you trust a stranger in putting a correct dial on the scoreboard? Answer: You don't, its drivers responsibility Going forward and all the bells and whistles go off and computer states dial in is slower then index and self corrects it. Its still not correct. 1) So now what will be said when a car is -1.00 under index and tower reverts over dial to class index dial in and driver does not notice and stages car? Answer: Driver is responsible for dial in has now excepted it. 2) Is this going to be ok when dial is still wrong and driver excepts by staging car? Answer: Yes as its responsibility to check dial in before pre staging. 3) Or will the complaining still continue and rerun be demanded? Answer: Yes Bottom line is driver is responsible for proper dial in before pre staging no matter what's on the board or when computer operator installs wrong dial even if dial in is 99.99 on score boards. Drivers need to take responsibility for your own demise. |
#79 |
Also, Toby stated that a addition to the system (dial in > index = index) would have self corrected Mr. Hills example of 2 cars in the same class and yet operator installs 1 car with slower then index dial in. Then this race would have been corrected and a heads up race would have been run properly.
#80 |
Liked 16 Times in 10 Posts
At the NMCA race at Atlanta in April, I was part of the first pair in round 1 of Stock Superstock. They had the correct dial in on the scoreboards, so we did a burnout. Went to prestage and the dial ins changed to index in my lane. They backed us up for several minutes to fix the problem. When it appeared to be fixed, they motioned us back up to stage. We didn't quite get staged and the dial in went back to index. They backed us up again. After what seemed like a long delay we were motioned back up. I did another burnout and pulled up to stage. Scoreboards changed again to index. Backup and wait. Finally they got the problem fixed and we finally got to run. Maybe they have computer problems that need fixing. Randy E
