Old 05-31-2017, 07:23 PM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default Fuel Table question
Camaro lt1 stocker.supposedly really good heads, all top notch parts. fast xfi 2.0, timing at 36 degrees. My question is what should my top rows on my fuel table read at wot. These are my numbers. At 4000 rpm and go to 7500 rpm increasing in 500 rpm increments..130-158-186-196-190-188-186-177. Fuel pressure is 60 lbs Just new to fuel injection. In alpha N mode. I might should switch to speed density. some people say is less confusing. Is that true?
Kdw1403 is offline   Reply With Quote
Old 05-31-2017, 08:35 PM   #2
Nmbr1GMfan
Default Re: Fuel Table question
Get a wideband and you'll know for sure.
Old 05-31-2017, 09:08 PM   #3
Ed Wright
Ed Wright's Avatar
Should have come with a wideband. If you don't have one, you need a data logger so you can play a run back to see what your actual air/fuel ratio at each 500 RPM cel in the fuel table. I use the FAST internal data logger.
A given set of numbers in the fuel table won't be right for every LT1 Stocker. Different cams, injectors, fuel pressure, headers and cylinder heads.
In AlphaN mode, yours will be different in different weather, and at different elevations.
Ed Wright 4156 SS/JA
