Old 06-07-2017, 12:11 PM   #1
Bobby DiDomenico
Liked 101 Times in 52 Posts
Question What engine is this?
My friend sent me this and said it is a twin turbo Buick T-Type.
I questioned that as my Grand National only had 3 plug wires per cylinder bank:-)
Is it really a new style Chevy?
Thanks guys!
Old 06-07-2017, 12:46 PM   #2
modelman1960
Liked 55 Times in 22 Posts
Question Re: What engine is this?
Thanks guys!
It appears to me to be a new generation big Block GM engine w/ a turbo charged induction system. The fender wells also appear to be from an older vehicle style. This could make a good " Guess what this is".
Walt
Old 06-07-2017, 12:51 PM   #3
Nmbr1GMfan
Default Re: What engine is this?
GM LSx in a T-type
Old 06-07-2017, 12:51 PM   #4
Bobby DiDomenico
Walt
Thanks! As an owner for 25 years, I'm sure the grill and body are a 1987 Regal. That engine is quite different than mine, good thing my friends don't work in tech:-)
Old 06-07-2017, 03:40 PM   #5
Click on the resize bar. Bigger is better:
Old 06-07-2017, 05:46 PM   #6
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Could it be GM's answer to the new Dodge Demon?
Lew Silverman #2070
"The Wagon Master" N/SA
Old 06-07-2017, 07:30 PM   #7
pmrphil
Liked 348 Times in 152 Posts
Did you happen to notice the AFR heads ?
Phil Molski
PMR Performance
S/C 1623
Old 06-08-2017, 12:09 AM   #8
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Rotated even better...
Rich Taylor
I/SA - 321
Old 06-08-2017, 09:42 AM   #9
Bobby DiDomenico
Thanks for that. Not being a Chevy guy I had been trying to google various Chevy heads to see the same end view without success.
I am baffled on that quarter of a pie shaped adapter piece between the throttle and the intake, it must be messing up the airflow with a sweeping curve on the upper side and a 90 degree bend on the lower side.
Old 06-08-2017, 10:43 AM   #10
Nmbr1GMfan
See post #3 it's a GM LS style engine, and the intake elbow doesn't really matter when there's 20 psi sitting on the back of the valve.
