Old 06-08-2017, 11:12 PM   #31
David Lee
Liked 346 Times in 126 Posts
Default Re: Hardblock?
Originally Posted by carl hinkson View Post
Those blocks are hard to come by .
Check with Ray Barton
and at over 3K
Old 06-08-2017, 11:27 PM   #32
James L Miller
Liked 25 Times in 16 Posts
Any special preparation needed before HardBlok? Is the standard hot tank good enough, or does it need special rust removal to get a good bond to the iron? I'm thinking muriatic acid inside with a water flush. Maybe follow with Evap-o-rust or is all of that overkill?
Found this online.
http://dalhems.com/f/d/808c931833604...str-022005.pdf
Mopar 2 Ya!
Old 06-09-2017, 07:29 AM   #33
Liked 1,912 Times in 429 Posts
The muriatic acid cleaning is an excellent idea. I don't use anything after that except a flood of good clean water.
I bolt a head to the opposite side of the block, and torque the main caps. Then I pour the first side, and immediately install a cylinder head and torque it. I let it set one week. Then remove the head on the other side, pour that side, reinstall the head, and let it set another week.
Old 06-09-2017, 09:43 AM   #34
randy wilson
Liked 22 Times in 22 Posts
Originally Posted by Monte Howard View Post
Save yourself the aggravation, I hard blocked my 010 block and went .060. With new cp pistons. After the 1st pass the car slowed down. Made about 20 more runs on it. Tore it apart this winter and the cylinders where .008 out of round. And my new pistons skirts where scuffed really bad. Do yourself a favor and just get a SHP block and be done with it.
This guy found the same thing I found out.
don,t have one
Old 06-09-2017, 01:00 PM   #35
SSDiv6
If you want the best, use MasterFlow 885, formerly known as Embeco 885.
MasterFlow 885 has a metallic aggregate, it is non-shrinking and way stronger than HardBlock or the Moroso product after cured.
Old 06-09-2017, 05:29 PM   #36
carl hinkson
Liked 18 Times in 10 Posts
My rule of thumb if you have to fill the block your using the wrong block,
Cylinders change during heat cycles and and never come back to the original machined size.
carl hinkson is offline   Reply With Quote
Old 06-09-2017, 06:06 PM   #37
David Lee
So every combo that can not get an aftermarket block should just stop building engines. That is what you are basically saying
Old 06-09-2017, 07:37 PM   #38
Jim Hanig
Liked 99 Times in 49 Posts
Which engine wòuld that be?
Old 06-09-2017, 09:42 PM   #39
David Lee
go look at the replacement blocks listed by the nhra, and try to find some of the rarer combo's. This idea having to run a replacement block and spend vast amount of money to compete will be the nail in the coffin for many people.
Old 06-10-2017, 01:47 AM   #40
Adger Smith
Liked 880 Times in 311 Posts
I have never experienced any of the out of round problems.
Over the last 30 years I have filled blocks for Circle track, Drag and mud racers as well as boat racers. A few years ago I took a late mod 305 and filled it and bored it to std. 283 for a boat race class. Freshened it once and I think it is still going.
I use a Machine grout and I let it harden at least a month before doing any machine work. I also increase the Piston to wall clearance by at least 40 -50 % . I always test piston growth before deciding on the final cold bore clearance. A water block cylinder moves, a filled block does not and the pistons still grow with the hot oil and combustion heat on them.
Allow for it. On the circle track Applications I only fill to the oil galley holes in the lifter bores. My theory on that is still have water in that part of the cylinder to pull heat out of the oil going through the lifter galleys.
Seems to keep oil temps in check.
Adger Smith (Former SS)
