Old 06-18-2017, 09:07 PM   #1
David Lee
Liked 346 Times in 126 Posts
Default marking rod and pistons
I am going to be pulling apart a bracket 340 and I am going to re-use the rod and pistons. And I have been told by very knowledgeable people not to use a numbered punch on the rods since they can induce stress risers. What is the best way to make these so they go back into the correct hole?
Old 06-18-2017, 09:32 PM   #2
Jason
Liked 8 Times in 5 Posts
Default Re: marking rod and pistons
Sounds like a BS story. Most factory rods are stamped with a numbered punch and they hold up just fine.
Jason is offline   Reply With Quote
Old 06-18-2017, 09:52 PM   #3
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
How about one of those electric etching tools you can pick up at Sears or Harbor Freight for less than $20? That would solve the problem of being a little too "heavy-handed" with a punch and ball-peen hammer.
Lew Silverman #2070
"The Wagon Master" N/SA
Old 06-18-2017, 10:21 PM   #4
David Lee
Jason, i want to return each piston and rod to the hole they came from, and no mopar rods are not numbered to go into a particular cylinder. And thanks Lew, I will look into that. I was also considering the pens that junk yards use to mark parts.
Old 06-18-2017, 11:50 PM   #5
GTX JOHN
David: I am surprised....Every 340 production rod I have every seen
is numbered 1 to 8 to Cylinder. Never had a problem stamping including
pistons. Excepting Some Chinese aftermarket stuff (Re: 440 Source rods)
John Irving
741 Stock
741 Super Stock
GTX JOHN is online now   Reply With Quote
Old 06-19-2017, 12:00 AM   #6
James L Miller
Liked 25 Times in 16 Posts
Almost all or all of the Chrysler V8s I've taken apart had the rods numbered (subject to old geezer memory). The number was maybe .09"-.12" tall as best as I can remember. I have a 340 on the engine stand, so I'll take a look tomorrow once the rain blows through. I probably wouldn't stamp the rods once the big ends were resized and new rod bolts installed. I think the rod bore only has a .0005" total tolerance on the bore size.
Mopar 2 Ya!
Old 06-19-2017, 01:08 AM   #7
David Lee
guess I should have been a bit more specific. This engine was built by someone unknown and it is not my engine. It appears to have scat rods and kb pistons. I went down to an auto parts store and bought the pens and was able to mark the piston tops.
Old 06-19-2017, 03:46 PM   #8
John Dinkel
Liked 265 Times in 69 Posts
Magic marker.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 06-19-2017, 11:52 PM   #9
Fred D Bartoli
Dave,
Clean the area with lacquer thinner. Put dab of dykem on them, use a scribe to make the #. Been doing it for years stays on a long time.
Fred D Bartoli is offline   Reply With Quote
Old 06-20-2017, 03:04 AM   #10
David Lee
thanks for the idea
