Old 07-02-2017, 09:43 AM   #21
Jeff Teuton
Liked 325 Times in 50 Posts
Default Re: 8 3/4 Chrysler pro gears?
I also have a complete Moser Dana 60 w/5.13 pro gear axle to axle. Call for more info.
Jeff Teuton 4022 STK
Old 07-02-2017, 11:26 AM   #22
Coleydog
Liked 53 Times in 38 Posts
All this bad vibe has made me change direction, going with Dana instead. Always heard the 8-3/4 was more efficient.
Old 07-03-2017, 12:21 PM   #23
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: 8 3/4 Chrysler pro gears?
I read a dedicated article comparing rear end efficiency in one of the old car magazines a long time ago. Of the rears that I remember they tested, this was the order of efficiency:
1) GM 12 bolt
2) Dana 60
3) Chrysler 8 3/4
4) Ford 9"
I believe it said that the biggest factor is the placement of the pinion in relationship to the ring gear. The higher the pinion (closer to center), the more efficient it is. The 9" has the additional disadvantage of an extra pinion bearing.
I don't recall what others were tested.
Somebody makes/made a 12 bolt style center section for 9" housings. Was it Jim Kinnett that had a 12 bolt or a Chrysler 9 1/4 rear in his SS/AA Cuda?
LOCOMOTION Racing
Old 07-03-2017, 12:25 PM   #24
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Red face Re: 8 3/4 Chrysler pro gears?
1) GM 12 bolt
2) Dana 60
3) Chrysler 8 3/4
4) Ford 9"
Kinnett ran a 12 bolt GM rear in both the Hemi SS car and the Pro Stocker. I have seen them both personally. Jim
Old 07-03-2017, 12:44 PM   #25
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
1) GM 12 bolt
2) Dana 60
3) Chrysler 8 3/4
4) Ford 9"
Hi,
Strange still manufactures an aluminum 12 bolt drop out center section that fits into a 9" Ford housing........
I wonder if that will pass tech (HA HA) for a GM Stock Eliminator car?????
Just sayin'
Bob Mulry 7516 STK
A & M Motorsports
Old 07-03-2017, 01:07 PM   #26
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
1) GM 12 bolt
2) Dana 60
3) Chrysler 8 3/4
4) Ford 9"
It's called hypoid distance. Dana 60 is 1.125". MoPar 8 3/4, GM 12 bolt and 10 bolt, AMC Model 20 are 1.50". Ford 9" is 2.25". The farther the pinion is from the centerline of the ring gear, the greater the angle of the drive teeth to the ring gear teeth and more friction. Bearing size is a factor for efficiency as well as rotating mass.
I remember that same article, but have since learned from other sources who have done serious experimentation that the Dana 60 is more efficient than the 12 bolt.
Old 07-03-2017, 04:27 PM   #27
SSDiv6
Dwight is correct; after much analysis, the final result is the Dana 60 is the most efficient of the bunch.
Old 07-03-2017, 04:30 PM   #28
SSDiv6
Originally Posted by Bob Mulry View Post
Hi,
Just sayin'
Bob,
The Strange 12-Bolt, 9" drop out has weight limitations on its use.
It's designed for very lightweight cars, dragsters and roadsters.
Old 07-03-2017, 06:26 PM   #29
Coleydog
Maybe someone will make more ratios again. Picked up another Dana housing yesterday, free
Old 07-05-2017, 09:48 PM   #30
Todd Boyer
Liked 6 Times in 5 Posts
1) GM 12 bolt
2) Dana 60
3) Chrysler 8 3/4
4) Ford 9"
I remember reading that Rick Johnson ran a 9 1/4 Mopar rear in his SS/AA Barracuda at one time. He may still.
