Old 07-11-2017, 04:16 PM   #1
TOM KASCH
Liked 241 Times in 100 Posts
Cool 1969 Zl-1 Camaro
A friend just called and his friend is rebuilding a 69 Zl-1.
Thinks it would be worth $1,000,000 when it's done.
I told him IF the numbers all match maybe $400/500, 000 at a big auction.
Where can I go to look up the vin #.....block #...head #..intake #, etc.
don't know much more.
Old 07-11-2017, 07:28 PM   #2
killintime6968
Liked 91 Times in 29 Posts
Default Re: 1969 Zl-1 Camaro
Go to www.yenko.net It has lots of info that might help.
Bruce Cameron
killintime6968 is offline   Reply With Quote
Old 07-11-2017, 07:57 PM   #3
TOM KASCH
thank's
what do you think it's worth?
Old 07-11-2017, 08:18 PM   #4
Cdncarnut
Cdncarnut's Avatar
Liked 56 Times in 31 Posts
For it to be worth $1,000,000 it would have to have to be united with its' original engine and transmission and date coded rear end. All internal drivetrain components would also have to be correct and dated.
The hardest part is that all the fasteners and brackets would have to be correct.
All these cars and their history are known by some of the people on Yenko,net.
I have been a member there since the mid 90's and that is the site to go to, if you need of have information.
These cars do not change hands very often.
Thomas
NHRA 1959 D/SA
Cdncarnut is offline   Reply With Quote
Old 07-11-2017, 09:25 PM   #5
Dana Fitzpatrick
Liked 10 Times in 6 Posts
I can't see it getting anywhere near a million,your estimate is probably close,if it's a no questions asked, real deal, born with engine,trans and BE rear end. And a high end restoration,or a survivor.Unfortunately, very,very few of these cars still have the born with engines.One of the two original RS ZL-1's might approach one million,nothing else.
Dana Fitzpatrick is offline   Reply With Quote
Old 07-11-2017, 09:31 PM   #6
Rick Brown
Liked 45 Times in 8 Posts
Hi Tom, there is a all original restored one here in Ohio a friend has but the best person to contact is a fellow Stock Eliminator racer Jerry MacNeish. Simply put his name online search with CAMARO and see his results. You will be impressed! There only a few original engine cars around. Good Luck. A VERY costly restoration to make it worth the number your talking about.
Rick Brown is offline   Reply With Quote
Old 07-12-2017, 03:20 PM   #7
TOM KASCH
were copo 69 Camaro 396-alim head or were they 427 Iron heads ?
500 were built from what I find.
Old 07-12-2017, 04:07 PM   #8
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Central Office Production Option (COPO) 9561 was a 1969 Camaro was 427-425hp L72 engine w/ ZL2 fresh air hood, HD cooling and 4.10 service package rear axle. Disc brakes were a mandatory option along with either 4-speed or automatic trans. No exact records are known, but there were about a 1000 produced. 396-375hp aluminum head L89 engine was RPO (regular production option)
Old 07-12-2017, 05:40 PM   #9
Albert Lee
Liked 258 Times in 49 Posts
Didn't the OP say this was a ZL-1?
Al Corda
Albert Lee is online now   Reply With Quote
Old 07-12-2017, 06:58 PM   #10
Dana Fitzpatrick
Tom, if your friends friend has not done so,have him check his dash vin against the easily located published list of the 69 ZL-1's. If it's on the list,remove the cowl panel and check the hidden vin stamped on the cowl.
If all the vins match one of them on the list,he might be in business.
The vins are on the Camaro Research Group website or Yenko .net.
