Old 07-29-2017, 06:54 PM   #1
rod
Liked 20 Times in 15 Posts
Default 350 hp 327 carb ?
where can I find the legal Holley carb. numbers for a 350 horse 327, years 65-67? also are there photos anywhere? I remember that a 2818 was an original carb. are there others?
thanks Rod in AZ
rod is offline   Reply With Quote
Old 07-29-2017, 09:08 PM   #2
kansas stocker
Liked 249 Times in 48 Posts
Default Re: 350 hp 327 carb ?
I'd suggest you register and use Dwight's site.
www.classracerinfo.com
kansas stocker is offline   Reply With Quote
Old 07-29-2017, 09:15 PM   #3
SSDiv6
Holley owns Quick Fuel.
Quick Fuel Part Number SSR-585-1VS.
https://webapi.holley.com/products/f...ts/SSR-585-1VS
Old 07-30-2017, 01:35 AM   #4
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Rod… A 3245 is an L-79 Carburetor. A good rebuildable core is very valuable and hard to find. The QuickFuel replacement would be the way to go. Contact Jimmy Bridges, he will be able to help you. MB.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 07-30-2017, 08:22 AM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Depends if you are looking to restore or race that engine.
Restore:
'65 - R2818 Corvette only, R3043 Chevelle only
'66 - R3245, R3367 Corvette only, and R3806( a late replacement carb). The R3367 was also used on 327-300hp engines and should not be that hard to find.
'67 - R3806, R3807, R3810 and R3814. These carbs were used on the 350 rated engine in the Corvettes and the 325 rated engine in Chevelles, since they are the same engine with different ratings. The R3806 and the R3810 were also used on the 327-300hp engine in Corvettes. The R3807 and R3814 are California calibrated carbs. As an additional note of interest, the R3810 and R3814 were originally spec'ed for use on '67 Z28s, but that was nixed before it went into production. And the 396-375hp engine is spec'ed with a variation of this series of smaller carbs with R3811 and R3815 designation, though you will never see them in real life.
Race:
For all years, use the Quick Fuel Part Number SSR-585-1VS; it's readily available new and has metering advantages over the old carbs for race use.
Old 07-30-2017, 07:32 PM   #6
Chevy55
Banned
Liked 179 Times in 89 Posts
ORIGINAL 1965 L79 Chevelle Holley Carburetor 327/350HP List 3043 dated 521
http://www.ebay.com/itm/ORIGINAL-196...pYxsBK&vxp=mtr
Chevy55 is offline   Reply With Quote
Old 07-31-2017, 04:20 PM   #7
my69396
Liked 46 Times in 20 Posts
Has anyone ever seen a R2818 original to a corvette? The reason I ask is years ago I bought a 1955 Belair 2 dr htp with what I believe was a 365/327 engine and the carb has four 1/8 in holes drilled in the body of the carb about a inch above the throttle plates. The car had been setting since a 1972 so I don't think someone had added them because they were all the same size and height. Just wondering if someone had ever seen anything like that.
my69396 is offline   Reply With Quote
Old 07-31-2017, 09:56 PM   #8
Gary Anderson
Can't say for sure about the 2818's, but I know the Holley 3 barrels have those holes.
Gary Anderson is offline   Reply With Quote
Old 08-01-2017, 01:52 PM   #9
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
thanks Rod in AZ
Bill Jenkins old A/SA Nova combination
D
