Old 08-02-2017, 04:18 PM   #311
David Lee
Liked 346 Times in 126 Posts
Default Re: Important if you run D-H/S or SA
Hi Paul, You're right, I've heard the horror stories but to quote David Lee, "it is not my problem".
Then, you have no argument against the manifolds,
Old 08-02-2017, 04:30 PM   #312
Billy Nees
Again David, I'm missing your point.
Billy Nees 1188 STK, SS
Old 08-02-2017, 04:37 PM   #313
David Lee
wow, is it that hard. How much hp does these non stock blocks give, answer that
Old 08-02-2017, 04:47 PM   #314
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
I just looked at Nitro Joe's stats, 62/65 competitors in D/SA have an aftermarket block listed available for their combo in the NHRA Accepted Products list (no Olds 455 or Buick 455 available, as far as I know). Yes, it is unfortunate there are not better blocks available for some combinations, but that doesn't make it ok to accept an intake manifold that's was originally listed by Mopar as "the result of an extensive dynamometer and track development program" and "for your super stocker, formula car, or bracket racer."
3207 D/SA, C/ED
Andrew Hill is online now   Reply With Quote
Old 08-02-2017, 04:52 PM   #315
David Lee
why are you just limiting to one class, billy goes after the 273 manifold regularly. Even in this conversation.
Old 08-02-2017, 04:56 PM   #316
Andrew Hill
This thread is discussing an intake manifold that is run in classes D-H.
If you're really concerned about an aftermarket block, make one or get one made, submit it to NHRA. You can do that if you really wanted to. I cannot make a manifold or get one made and have NHRA accept it.
3207 D/SA, C/ED
Old 08-02-2017, 05:36 PM   #317
SSDiv6
how much hp is picked up by having beefier blocks that will allow a better cylinder
You lost me at "Blocks that will allow a better cylinder".
Why are you complaining about the blocks when the subject is about intakes and cylinder heads?
The majority of the racers are going fast with the OEM block both filled and unfilled.
It boils down to the quality of the machine work and the final finish of the cylinder walls.
Old 08-02-2017, 05:53 PM   #318
David Lee
So wall thickness and deck thickness have nothing to do with a better seal. And if so many racers are going fast, with stock blocks, why the need for aftermarket blocks.
And you want to limit it to that one subject.
Old 08-02-2017, 05:57 PM   #319
Todd Hoven
Guest
Posts: n/a
David, what side of the crusade are you on? What would you like to contribute to the conversation? Do you feel that the lack of an aftermarket block for the 273-360 is reason enough for the allowance of non OEM Cylinder Heads and Intake? Am I understanding you correctly? Just clarifying
Old 08-02-2017, 06:11 PM   #320
David Lee
I am, and i see people like you and Billy doing a lot of tap dancing. How much extra hp does aftermarkets give?
