Old 08-06-2017, 09:20 PM   #1
Woodfin
Liked 288 Times in 109 Posts
Default for what it is worth, bushed vs needle roller lifters
With the original build, we installed a bushed roller lifter. With the rocker arms removed the engine assembly would rotate easily and smoothly with an 18" bar on the damper bolt. As the rockers were installed, it required turning the engine with the starter to assemble and adjust the rockers. The rotation effort was very high.
After a tear down to make some changes we installed to a needle roller lifter. Now, the completed assemble, including rockers can easily be rotated with the 18" bar.
The rotation effort by hand is significantly reduced. This is an unscientific observation and may not make any difference once the engine is spinning.
Old 08-07-2017, 07:57 AM   #2
Woodfin
Default Re: for what it is worth, bushed vs needle roller lifters
on another forum, this was suggested
"Yes the bushed lifters have way more drag when turning at hand speed (no hydrodynamic lube condition at this speed) compared to needle rollers"
Old 08-07-2017, 09:12 AM   #3
Hacksaw
Liked 312 Times in 175 Posts
How about checking the rotational drag as someone is priming oil pressure? Should make a big difference, right?
Old 08-07-2017, 09:35 AM   #4
Dragsinger
Liked 99 Times in 60 Posts
Hack, you have a reasonable test and I would do so if the engine was not already assembled.
I will keep this test in mind for the future
Larry Woodfin 471W
