Liked 8,210 Times in 1,536 Posts
HP will be delivered on Monday to J Randall and J Olson in stock eliminator........Very Impressive ......At least they were in the correct class. !!
Liked 13 Times in 7 Posts
Being new to this, I'm trying to wrap my head around how all this works as regards to additional weight that's going to be added.
I know from what times are shown on these two combos that the minimum change is going to be a HP hit of 3.25% from the AHFS chart, right? Does that become the percentage of extra -weight- per that class/combo that must be carried? Like 3500 lbs X 1.0325 = new factor of 3614 ?
Brian Saunders Lerna IL '79 AMX T/SA 3790 currently being resurrected |
#3 | |
Liked 7 Times in 5 Posts
rb |
#4 | |
That helped a bunch. Thanks.
Liked 80 Times in 29 Posts
The appropriate percentage increase based on performance is applied to the factored HP rating.
"Adjustments are rounded up to the nearest full horsepower even if the fraction is below 0.5 horsepower. As an example, 2.15 horsepower is rounded to 3 horsepower. The quickest run, by the combination being reviewed, is used to determine the adjustment percentage." |
Liked 601 Times in 213 Posts
Sometimes requesting a horsepower reduction is not such a good thing. I requested and got the Mopar 440/375 reduced 5 HP for Super stock. Big mistake.. it kept me from running SS/EA....Much more favorable than F and G. My car does not like weight.
For those of you building cars and worried about getting a horsepower hit...don't worry about it. Bracket race your new car first. You will probably be a second off.
Gary Hansen - SS/FA 4911, B/SA 4911 Last edited by SStockDart; 08-19-2017 at 12:25 AM. |
Chevy 350 with a Quadrajet goes to what , 218 now? Oooh wow!
How come the stick gets hp with the automatic, and vice versa? The V6's have separate ratings.
Liked 5 Times in 4 Posts
The 86 P/U 350 / 212 gets a 4.25% increase making the new HP 222 the bad news it can only run N-O-P now. As Mr MJ says adding weight never helps and couple that with the lower index that never helps as well.
