Old 09-14-2017, 05:34 PM   #1
David Lee
Liked 346 Times in 126 Posts
Default Location for relays for fan fuel pump etc...
I am mocking up items in the engine bay of my stocker build. i will be running a electric fan and water pump. The instructions say yo have the relays as close to the power source as possible. I would rather have all of my electronics in a single location (most likely in the passenger area.) Can I get some opinions on this matter.
Thanks
Dave.
Old 09-14-2017, 05:57 PM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Location for relays for fan fuel pump etc...
Where's your battery? Mine's in the trunk but the main power feed still runs under the car to the firewall so the driver's compartment is close to the power source. Main thing is to use the proper size wire for the distance and amps you have to run. I built a circuit board with all relays to run stuff on my Mustang that had been giving me electrical issues. It still had street wiring left over from last year. It's under the glove box on the passenger firewall and drives everything. Dual fan motors, fuel pump, water pump, vacuum pump for power brakes, lights, you name it. Not pro looking but does the job. I have a map to remember where everything is wired in.
I used prewired relays from Pico wiring that come in sockets with color coded 14 gauge wire. Easy to work with and very high quality.
I had worked piece by piece in wiring this car up to this point, but I took time and designed the wire board on paper and built it on a workbench. I recommend the latter approach.
Dale Shearon
68 Mustang 6394
Old 09-14-2017, 06:31 PM   #3
David Lee
Since this a stock elim car, in the engine compartment
Old 09-14-2017, 08:47 PM   #4
Hacksaw
Liked 312 Times in 175 Posts
Put the relays close to your power suckers and in an accessible spot.
Old 09-14-2017, 09:18 PM   #5
There ya go. Now you can run radio speaker wire to your toggle switches to trigger the relays.
To each his own, but I put my w/p and fan switches to the driver's left so he can access them in the staging lanes.
Of course,I don't buy switch panels to hang off the roll cage.
Of course I usually don't have a roll cage anyway.
Old 09-14-2017, 10:27 PM   #6
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
David…I have a relay bank in the glove box. A lot of the prewired relays can be clipped together and mounted neatly with a small sheet metal bracket. MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 09-14-2017, 10:35 PM   #7
David Lee
Thanks. I was going to make a bracket to hold as far as I know now to be three.
The fuel pump, fan and water pump.
Old 09-14-2017, 11:52 PM   #8
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I have everything mounted behind the glove box door...switches are on the driver's side.
For some bullet proof/compact components check out Leash Electronics... http://www.leashelectronics.com/
Rich Taylor
I/SA - 321
Old 09-15-2017, 12:16 AM   #9
David Lee
Thanks that is exactly what I was thinking.
Old 09-15-2017, 12:46 AM   #10
Yes, all nice and neat looking, but DC power diminishes with wire length.
Also, as stated , the w/p and fan both use a bunch of amps.
Best to keep the the wire large and the run short on those items, in my opinion.
