Old 09-17-2017, 06:21 PM   #271
KEN BUGAJ
Liked 18 Times in 7 Posts
Default Re: Crate Motor Class
Xx
KEN BUGAJ is offline   Reply With Quote
Old 09-17-2017, 07:02 PM   #272
Ed Wright
Ed Wright's Avatar
Originally Posted by KEN BUGAJ View Post
IHRA already has Stock /GT and SS/GT has been around well over 25 year's in NHRA and IHRA. The young guy's and gal's can't afford to race. Next time you're at the races look around and see how many are out there. Not to many out there can drop 30 or 40 K on a Stocker much less 75 or better on a Super Stock.
They can bracket race. It has become too much like that now anyway, unless we have a heads up. If you have a "low budget" car, you likely would not enjoy one of those anyway.
I mean, I'm offended I can't afford to run Comp. I think, to be fair to poor guys like me, NHRA should make some classes for basically Stock engines for guys like me trying to race on their Social Security checks. :-)
Ed Wright 4156 SS/JA
Old 09-17-2017, 08:38 PM   #273
KEN BUGAJ
Eddie
Old 09-17-2017, 10:17 PM   #274
Ed Wright
Ed Wright's Avatar
Eddie, Eddie, what a comedian you are. If you want to run comp, get a second job...
Same advice to you if you want to run NHRA Stock.
Old 09-18-2017, 08:03 AM   #275
Todd Hoven
Guest
Posts: n/a
How is putting a different engine in a stocker going to be cheaper? Where can you buy a 2500$ engine that can run stock? Explain to me the savings? Do you think a stock ZZ4 or a stock 5.3 LS out of a pickup truck in the salvage yard will run the index in any car? Do you think it will be competitive in a heads up? Will it qualify for Indy? Unfortunately our class isn't what it was in the 60's and 70's. There are 40 and 50 K engines in stockers now that run A through E. You had some expensive rides back in the day. You should be able to relate
Old 09-18-2017, 09:48 AM   #276
KEN BUGAJ
Bb
Old 09-18-2017, 10:20 AM   #277
Jim Kaekel
Liked 535 Times in 110 Posts
Stock Eliminator is alive and well. We had over 120 cars at the Indy LODRS event last month.
Jim Kaekel 3836 STK
Old 09-18-2017, 10:33 AM   #278
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
The biggest problem with adding crate motor and Pure stock classes to NHRA competition is that there is already too many different classes in both stock and Super Stock. There is nothing wrong with these two classes but there has to be a line drawn when it comes to the amount of classes. Super Stock is already out of control wit GT. FSS and the modified classes. Modified, Super modified, and the modified trucks need to be moved over to comp and revise the comp class to something that can survive and get a car count. NHRA racing is not for everyone. If you want to race an NHRA class then you have to build or buy a car that fits those classes. Simple enough.
There is no cheap way to drag race at this level anymore.
Mike Pearson 2485 SS
Old 09-18-2017, 11:51 AM   #279
goinbroke2
Liked 398 Times in 157 Posts
Heard the same argument from fast cars being beat by cheaper slow cars etc.
Can a crate motor car throw any cam in it? No.
Any head? No.
Any valvetrain? No.
So what makes it a crate motor? Well, you have to run a particular set of parts as per their part number. The carb is a 750 holley for small blocks and 850 for big...can I run any carb on a crate? No!
So what's left? Ahhh...the intake. ANY intake is allowed, which is like totally different than a LD340 intake on a ....or a certain intake on 283's....or....
If the rule says "you must run xyz part to be legal" is that a spec or not? Can you deviate from that spec or not?
So basically, the fight is about allowing people to use easier to find parts instead of 50 year old cast iron.
What if the rule said factory intake and carb? Well then the only difference between a crate motor and a traditional stocker would be the heads. THAT'S IT!
And if you can't find 50 year old heads, you ain't gonna find 50 year old intakes and carbs any easier!
Wife looked up the coyote crate motor yesterday on amazon, $17,000. I said WHAT??? that can't be right, must include electronics etc but she already had switched so I never got to read it.
Would you guys feel better if crate motors cost $17,000 and you couldn't build it yourself? Then the game is again set for the richer ones?
Old 09-18-2017, 02:05 PM   #280
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
My car came from the factory with an LT1 engine, and that is what is in it now. It is a '96 model, I bought in 1997, it was 18 months old with 36,000 miles on it, with an LT1 engine & automatic transmission.
You evidently built that car for IHRA, you can still run it there, right?
You can also bracket race it at NHRA tracks, right?
But, expect THE major sanctioning body to make new rules for you?
You built the wrong car for NHRA, other than et brackets.
You did not understand that when you built it?
NHRA should adopt the IHRA Classes.
Did not have any problem creating a class for the COPO Manufacturers built race cars or ProMod for that matter?
