Old 09-28-2017, 12:34 AM   #11
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Bogart wheel cracked again!
https://www.championbillet.com/drag-wheels/
Rich Taylor
I/SA - 321
Old 09-28-2017, 06:22 AM   #12
denbreeden
denbreeden's Avatar
Liked 67 Times in 27 Posts
Originally Posted by Bob Mulry View Post
How fast do you drive around corners??
I have seen cars exiting the shut down area at speeds that scare me.
Side loading causes the wheel to flex and flex causes work hardening which leads to cracks..
I know how heavy my car is and I baby it around corners..
Just sayin'
I take it easy, always have. These Challengers are nose heavy.
denbreeden is offline   Reply With Quote
Old 09-28-2017, 07:13 AM   #13
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Bogart wheel cracked again!
This problem has been discussed before several times. Holeshot Wheels make a wide variety of one piece and 3 piece wheels. Good balance of weight & strength. My car is 3,560+.
One piece selection: https://holeshotwheels.com/collections/1-pc-wheels
I've run Holeshots for many years without such issues, but everything should be checked/replaced periodically. Just recently I've had my second OEM 2007 Pace Trailer aluminum wheel develop a leak through the aluminum. Nothing was visible, but apparently the porous aluminum developed a crack after years of use. The trailer has stayed below it's 12,000 lb rating at around 10,500.
LOCOMOTION Racing
Old 09-28-2017, 07:15 AM   #14
hilton
Liked 14 Times in 7 Posts
One brand of racing wheels that is overlooked and of great quality is Lindsay Racing Products in Peoria, Arizona.
http://lrpwheels.com/
Nice looking wheels no prices ?
hilton is offline   Reply With Quote
Old 09-28-2017, 09:52 AM   #15
Signman
Liked 269 Times in 99 Posts
FWIW
How the car is tied down in the trailer may be the problem or part of it.
If tie downs are parallel the car will not move forward or back but will rock side to side while on the road.
Cross or X tie downs front & rear side loading is greatly reduced.
Also tie down the car so it will not move up & down this will wear out your shocks in a few trips. May require adding more tie downs.
Old 10-05-2017, 02:16 PM   #16
Jim Carter
Liked 19 Times in 3 Posts
Bogart makes a back plate version for the spoke wheels.
It comes black and might do the trick.
Jim
Jim Carter is offline   Reply With Quote
